Old 06-15-2015, 04:05 PM   #11
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
I'm looking at this one with Toshiba compressor.
KSIN012-H115 12000 BTU Mini Ductless Split AC - Heat Pump
Pretty close to me in Michigan.
Old 06-15-2015, 06:34 PM   #12
going to the "save" file
Old 06-15-2015, 06:55 PM   #13
so, theoretically these 115v mini split systems could be mounted to the rear bumper providing you don't block the tail lights or in a frame mounted above the tail lights... heat & air in one hit!
A single 12000 BTU probably wouldn't be enough to cool/heat the whole bus, but it gives me an idea where to start... seems like a better option that a cooling only unit sticking out of a window.
Wonder if you could mount two of the condenser units under the bus, and put a mesh grill in the skirt, so the fan could operate normally.
Old 06-15-2015, 07:00 PM   #14
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
That would make more sense, especially with an RE
Captain Obvious on deviantArt
Old 06-15-2015, 07:09 PM   #15
Coachwork: Ward/AmTran
The "heat" would be ok here in Florida.
My current plan is to use one of the 12k btu splits and a small 5k btu in one back window. That would be enough to cool it I think.
Old 06-15-2015, 07:16 PM   #16
juliol's Avatar
Engine: 3208 turbo Cat
Would something like this work?
24000 BTU Dual Zone Energy Star Mini Split 21 SEER - 12000 x 2
J
juliol is offline   Reply With Quote
Old 06-15-2015, 08:11 PM   #17
Engine: TE 444
Rated Cap: 12
just for your information, my 35 foot bluebird wanderlodge left the factory with 3 20,000 btu AC units, not sure how much insulation it has but more than a school bus, the walls are twice as thick
I was thinking a 24K BTU unit and 2 inside wall units for my 28 foot bus, not sure if it would be enough though
Old 06-15-2015, 08:20 PM   #18
Engine: 190hp 5.9 Cummins
Again, all of our needs will be different.
Amount of square feet of windows, and type / thickness of insulation, climate used in, outside color of the bus, fridge inside, ect.
I like adding money on insulation, proper color, roof deck (Shade), ect now VS spending a ton on heating and cooling throughout the life of the bus.
Old 06-15-2015, 08:26 PM   #19
Chassis: I.H.
Originally Posted by juliol View Post
It states 220v.
Old 06-15-2015, 08:34 PM   #20
Engine: TE 444
Rated Cap: 12
another option, one I already have, you just hang the 2 hoses out a window, first thing I am going to try to cool the bus
Amazon.com - Whynter 14, 000 BTU Dual Hose Portable Air Conditioner (ARC-14S) - Portable Ac Unit
and you really want the 2 hose versions
