Originally Posted by somewhereinusa
I just measured mine 553 Kwh 12500 btu, about 85 degrees sitting in the sun.
That does not look right.
Residential A/C units have SEER ratings between 14 and 25.
That is the ratio of BTUs cooling divided by the Watt hours consumed. It is typically averaged over the entire season but it can be calculated for one hour and should be in the ballpark.
Your unit would have a SEER of .023 with the numbers you provided.
It is more likely that your hour of operation consumed 553 Wh (1 kWh = 1000 Wh).
