Old 05-07-2018, 11:32 AM   #1
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Need help! Interlock I think
Having trouble starting a 2000 Thomas saf t liner
Getting buzzers air probably
Can jump the starter it turns
No indicator lights on trans, push button style
Cat motor, turns over when starter is jumpered
All emergency doors are closed
I think it's the interlock but don't know and can't find how to disable my year the videos I find are different years and don't line up with what I got in my panel
Thanks for any help from all you awesome bus folks
Whatthefak is offline   Reply With Quote
Old 05-07-2018, 04:29 PM   #2
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Not the interlock, went through each one. All the switches are ok all doors and hatches shut.
I don't know wtf to do
Old 05-07-2018, 05:37 PM   #3
brokedown's Avatar
The interlock on my shortie's back door was flaky and sometimes you had to wiggle it to get it to start. I was happy to disable that one and leave the others in place. ON my new bus I removed them all and the entire length of wire all the way back. It's a small sample size but my short bus had a 25% failure rate!
Old 05-07-2018, 05:39 PM   #4
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
I want to pull them all, but I'm more worried about getting it started, I've rules out interlock I can set off and stop the interlock alarm but I have no ecm or lights on the trans
Old 08-22-2018, 08:02 PM   #5
01ThomasMVP's Avatar
Chassis: Thomas MVP
Engine: CAT 3126
Hey man I was checking out your bus when u said you had a similar one to mine. It is very similar looking and same type of engine. This might be a no-brainer to you but if you still haven't gotten your bus started, it sounds like the same issue I had. I thought it was the interlock for awhile but then I finally figured out DUH! the batteries were dead. Like i said might be a no-brainer to you but took me a bit to figure out lol. The buzzers would go off and lights would work and engine would crank a few times but not turn over. Got some new batteries and it started up no problem.
01ThomasMVP is offline   Reply With Quote
Old 08-22-2018, 08:05 PM   #6
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Got new batteries
Turned out to be the ecm was bad
Old 08-22-2018, 08:08 PM   #7
Chassis: Thomas MVP
Engine: CAT 3126
Oh damn was that an expensive fix? What caused it to fail? Just wanna know in case I run into the same issue.
Old 08-22-2018, 08:19 PM   #8
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
I have no idea, it ran was parked for two year then didn't start
A super nice guy on here hooked me up with one for 250(still waiting for him to tell me where to send money)
It's an easyish fix but unless you find a used one a reman is like $800-900
The plus side of the cat motor is that they are everywhere the downside is some shops don't want to deal with them
Also everyone I've talked to said keeping the oil real clean is more important for cats so I may add a bypass filter
Old 08-22-2018, 08:33 PM   #9
Chassis: Thomas MVP
Engine: CAT 3126
Hmm alright that's somethin to consider. From what I've heard tho, cats are good and with allison tranny ppl have told me it's a good one.
