Old 08-15-2011, 08:43 PM   #1
Chassis: Chevrolet
Engine: 8.2L Detroit Diesel
Rated Cap: 54
Need help on a very simple 12 volt setup, please.
I have my bus wired completely for 110 AC. When I am boondocking, as I do 97.452% of the time, I use deep-cycle batteries and power inverters to run lights, stereo, etc. Last year I acquired a 1987 26-foot Layton travel trailer. I realized how efficient its 12 volt system is for operating a fan and lights, versus the above-mentioned system in my bus. I would like to run a very basic 12 volt system and I need help. I want to have my battery, obviously, with 16 gauge wiring running the length of the bus. Along the way, I want two 12 volt interior RV-style lights and one 12 volt socket for charging cell phones and so forth. Maybe a small 12 volt fan in there, too. It's a simple system. But I want my system protected with a fuse. Could someone please tell me what type of fuse I need and where it should fit into my setup? Thanks for your help.
-Adam
arfisher83 is offline   Reply With Quote
Old 08-15-2011, 08:57 PM   #2
Chassis: Tc2000
Engine: 5.9 Cummings turbo diesel
Re: Need help on a very simple 12 volt setup, please.
Instead of fuses, I went with 12 volt marine circuit breakers. They are a little more up front, but keeps you from having to stock fuses and keep up with them. You can find them on eBay for a resonable price. As for the size of the fuse or breaker, it all depends on the device you are putting on it, check to see what they recommend. If you are pulling some stuff out of the Layton, or trying to copy it, check the fuses it has. As for the 12 sockets, check your car's fuse panel, mine has a 5 amp.
Great nations rise and fall. The people go from bondage to spiritual truth, to great courage, to liberty, to abundance, to selfishness, to complacency, to apathy, to dependence, and back again to bondage.
kc_4_jc is offline   Reply With Quote
Old 08-15-2011, 09:18 PM   #3
Chassis: Chevrolet
Rated Cap: 54
Ok, thanks. I'll check the fuses in the Layton when I can locate the fuse panel. I know there's one in there somewhere.
Old 08-16-2011, 09:44 AM   #4
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Whether you are using fuses or circuit breakers, keep in mind the fuses are meant to protect the wire, not the components. Place the circuit breaker / fuse as close to the source of power as possible. You don't want a short circuit to turn a length of wire into a makeshift fuse.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu∑di∑crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 08-16-2011, 09:03 PM   #5
Chassis: Chevrolet
Rated Cap: 54
I've heard most trailers are wired with 16 gauge wiring. Is this true?
Old 08-17-2011, 10:58 AM   #6
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
depends on what the wire is hooked to. I HOPE they consider the max load when stringing lights etc.
Old 08-17-2011, 10:48 PM   #7
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Go LED lights. even if you have a reading light-light over the stove etc.-you don't have to use those all the time. I have a couple of 7 light strips facing up reflecting off the ceiling-it lights the bus with nice indirect light. And burns very little volts.
Simple way to plug in? Kathy WI Electrical, Charging and Solar 17 07-17-2013 12:13 AM
Simple distribution box Dain Alternative Fuels | Electric, Propane, Wood Gasification, etc. 1 06-10-2012 03:13 AM
Question: Simple solution to having electricity?? New Earth Electrical, Charging and Solar 37 04-13-2010 10:27 PM
Question: Simple solution to having electricity?? New Earth Conversion General Discussions 1 04-05-2010 12:55 AM
