Old 11-10-2018, 05:34 PM   #1
shaymcquaid's Avatar
Chassis: 40' MVP-ER
New Bus /First problem
Hello all.
Tried searching but....
1999 Thomas MVP-RE/cat 3126/Allison 3060
Got my bus home from Seattle to Dallas last night��
Went to show it off to my wife and now a buzzer wont shut off.
It is the one to the left side under the console.
We did open all the doors and close them back.
The local buzzers to the exit are silent.
I don’t know what to do about it��
If you need additional info just ask.
Thank you Thank you Thank you
-Shay
shaymcquaid is offline   Reply With Quote
Old 11-10-2018, 06:50 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
The buzzer is a "Kid Left Onboard" buzzer. Before you shut off the engine, you have to walk to the back and press a RED button. To permanently disable this, you have to open the outside electrical panel (under the driver's window) and disconnect a yellow module. You can also take this beast to a local Freightshaker dealership.
Old 11-10-2018, 11:25 PM   #3
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Unbelievable, the crap that's dreamed up to treat the rest of us like idiots because some don't do their job... *smh*
"Cheese Wagon" <anomaly.va@gmail.com>
Former owner - 1989 Ford B700 64-pass Blue Bird (Rest In Peace, Cheese Wagon)
Old 11-11-2018, 09:07 AM   #4
Chassis: 40' MVP-ER
Thanks for replying...
Looked for the no child left behind button. Cant find it.
Thing is though...Had three people on it for 3 days and this didn't happen!
Bus starts and runs. Probably just buzzer delete
Old 11-11-2018, 09:24 AM   #5
Have you ruled out the "low air" buzzer?
Old 11-11-2018, 06:32 PM   #6
Chassis: 40' MVP-ER
Its not low air buzzer. I just deactivated the buzzer
Old 11-11-2018, 07:08 PM   #7
joeblack5's Avatar
Year: 98
low coolant buzzer? low hydraulic oil?
Old 11-11-2018, 07:42 PM   #8
DO remember to re-connect that low air warning.
Old 11-11-2018, 11:51 PM   #9
Chassis: 40' MVP-ER
I un hooked the buzzer from the yellow module. (Emergency exit brain)
Is all good now.
Took my wife to the truck wash and to breakfast in the beast
Surprisingly easy to drive and maneuver.
love this bus
Old 11-12-2018, 10:56 AM   #10
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
when my rear transponder failed, I unscrewed the module from the front of the bus and pulled the wires out. I gave one a tug and it came apart and started sparking violently so I yanked the whole connection apart --x-- and separated the wires. Taped them up and put them back in the hole. Problem solved. I understand some systems are more advanced than others. Mine was just the controller box with wires that connected to the power, horn and light relay.
CMORGANSKOOL is offline   Reply With Quote
