Old 02-24-2018, 02:52 PM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
New project hidden compartment
I'm working on a new project. A hidden compartment with a hidden lock. Here's the controller.
Click on the picture it will take you to the video.
I have no problem with showing this. First you would have to find the compartment, then find where the controller is hidden in a wall somewhere. Anyway thought you might enjoy.
Old 02-24-2018, 10:13 PM   #2
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
Pretty cool. We plan on putting one in our Skoolie as well.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 02-24-2018, 11:10 PM   #3
Robin97396's Avatar
Secret hiding spots, HA! I'm going to put a secret passageway in my bus.
Robin
Nobody's Business
Old 02-24-2018, 11:18 PM   #4
Yep. I'm planning a hidden stairway, myself.
Dave in Tucson is offline   Reply With Quote
Old 02-24-2018, 11:32 PM   #5
plfking's Avatar
Rated Cap: 34
Do you have a problem with telling us what you're hiding?
Don
The Busted Flush
Old 02-25-2018, 07:08 AM   #6
Chassis: AARE
Probably just money, valuables maybe guns.
Old 02-25-2018, 07:51 AM   #7
Chassis: AARE
It occurred to me that some might not know what they are seeing. The module uses hall effect sensors and will be hidden in a wall. It will control a simple automotive type door lock actuator. The LED is extra, it will be hidden in the wall as well, I just wanted to play with one of the rgb LEDs i just received.
You use a magnet to activate the switch. So even if you find the compartment you have to know where and on which wall to hold the magnet.
I've seen it done to deploy the ramp on handicapped vans. The sensor was inside one of the tail lights. Not really very secure since there was a circle where you held the magnet and they were all alike and, to my knowledge, no way to disable it.
Does anyone know of a way to inexpensively make a space kinda fireproof? None of the searches I've done have come up with anything.
Old 02-25-2018, 10:50 AM   #8
Robin97396's Avatar
Hiding spots are a great idea. I’m not figuring out where there can be hollow hiding spots in this big metal box. The end caps and dashboard come to mind as logical hiding spots.
If you’re going for a floor hatch under the carpet, you’ve stolen my idea.
Robin
Nobody's Business
Old 02-25-2018, 08:20 PM   #9
Jdawgsfanasty's Avatar
Aimed at heaven?
Jdawgsfanasty is offline   Reply With Quote
Old 02-25-2018, 08:21 PM   #10
Originally Posted by Robin97396 View Post
Hiding spots are a great idea. Iím not figuring out where there can be hollow hiding spots in this big metal box. The end caps and dashboard come to mind as logical hiding spots.
If youíre going for a floor hatch under the carpet, youíve stolen my idea.
My too
