Old 10-10-2017, 12:24 AM   #11
StaceyDemir's Avatar
Originally Posted by Twigg View Post
You need to calculate your expected electrical load over a 24 hour period, in amp hours.
Then decide how long you will have to go without re-charging the battery(s).
Expect to double your final figure as the amp hour requirement as you don't want to discharge the batteries by more than 50%
So, if you have 600 Amp hours of stored capacity, you can use 300 Amp hours before needing a re-charge. So that would be 300 Amps for 1 hour, and 3 Amps for 100 hours. It's not quite that simple, but you get the drift.
There is a point where simply buying batteries isn't the answer because of weight and cost. A small inverter generator is quite capable of topping up the batteries with a few hours running.
All of this is simply a guide to how long you can "boondock". Solar power increases that time because the solar will put charge in the batteries too.(Actually that's all the solar does ... charge batteries and contribute to inveter output).
It's not whether a single, or multiple batteries will power an individual item like your laptop, but more a case of how long you can power the items you want to run.
When you say small inverter generator like 1000watt one? There is a sportman brand 1000 Watt Inverter*on sale for 199. Would that be better than my dcv 20r inverter and a 100 watt solar kit?
Sent from my LGMP260 using Tapatalk
1961 blue bird gmc conversion v6 401 ci
StaceyDemir is offline   Reply With Quote
Old 10-10-2017, 12:26 AM   #12
Rusty's Avatar
Engine: 5.9L Cummins
Rated Cap: '00
Body style FAQ
Popular Engine/transmission FAQ
Buying a used bus, what to look for?
How do I get my bus home?
Electrical FAQ's
Overview and load calculations
DC systems
AC systems
Generator
Solar
Where do I start?
Air conditioners. Road and parked.
Off the top of my head, those are most of the "daily" questions. What have I missed?
CDL needed?
Insurance
Re-title as RV
Painting
Insulation
Seat removal
Rivet removal
Parking/HOA/storage
Tires-date/type/rims
Rear-end ratios
Roof Raise
& Best order to do all the above !!
What I do when nothing is on tv... : My Nemesis
Old 10-10-2017, 06:44 AM   #13
There really isn't a "better" in this situation. 1000W of generated power is 10X the power of a 100W solar panel working at maximum efficiency, but if the load on your system is less than 100W, then the generator would be superfluous ...
EVery aspect of an electrical system affects all of the others, so you really need to plan the components according to need, and that starts with the load you expect and where, and when you will be using it.
Steve Bracken
Old 10-11-2017, 06:40 PM   #14
If i want to boondock do i need an inverter or is that dcv thing good enough.
Old 10-11-2017, 06:45 PM   #15
Year: 93
Engine: 7.3 idi
You should google handy bob and read his blog. Hes a wealth of information. Especially on solar
Greatestrr is offline   Reply With Quote
