No electrical at all on the bus
I have a 1997 Flat face, front engine Blue Bird bus with air brakes.
I was checking the lights and blinkers on my bus while getting it ready to move from my friends drive way last weekend when I first started it, it started right up just like every other time before. After checking everything, turning it off and then turning it back on literally a few seconds later it wouldn’t start. Suddenly I have no electrical at all, not even in auxiliary. I had started the bus many times before with the windows remove and the wires to the two hatches on the ceiling clipped. What had been changed more recently is the alarm on the back door had been removed, the magnetic sensor on the front, main door had been cut and partially removed, and the stop sign was removed as well. The Stop sign was removed, wires cut and the air line going to it disconnected. I didn’t cap the air line right away, but it is now, I do think the two air tanks under the bus are now empty.
I got power inside the main hatch just outside the driver side window as far as the inlet side of the 100 amp solenoid coming from the frame, no power coming out the outlet side and nothing making from the circuit breaker it goes to next or the bus bars after it. I’ve replaced the 100 amp solenoid and it changed nothing. I feel as if this is some sort of safety feature or a bad ground, just not sure and electrical things in vehicles are not my strong point.
I have been told to remove the cut wires for the main door all together. I have been told to bypass the 100 amp solenoid and jump the first circuit breaker to the 1st bus bar. I have also been told to remove the yellow control box for the amber lights and it’s wire from the system. I will be trying all of this tomorrow but wanted to get another opinion and to see if I could find someone who might have a better understanding of all this.
You can see photo’s and a bit of info on my Instagram at jamies_skoolie. Thanks in advance for any help you can offer.
