Originally Posted by JDOnTheGo
I'm not sure what sort of connector would be best but I might be inclined to install a switch to minimize arcing. Or.. just toss a blanket over the panel (or lay it face down) when connecting/disconnecting. If 100W, we're talking about only a few amps (less than 10) so all of what I said is probably overkill.
Yes I will cover it if I do this, I will make a good cover for safety and also to protect the panel.
Good idea I can install a switch before my connections.
Originally Posted by john61ct
Go to a High Voltage to reduce wire gauge needed, SC at the battery bank of course.
Or consider breaking your bank into separate packs and rotating them out to where the panels are. LFP would be ideal for that, even 100Ah can be toted around by my 12-y.o., and they'll keep soaking up the input until fill, unlike lead's inefficient current tapering.
Rigid suitcase style much more robust than the semi-flexibles.
Andersons for frequent disconnects, not MC style.
And of course beware thieves. . .
I forgot about micro inverters! Might look into it
Yes I think I'll pay the price and go lipo makes more sense. Honestly think 1 may do the trick for me, small DC chest, 12 water pump, and 12v lighting, 120 outlet will be for charging cellphones. This is going to be a weekend camper setup.
But it will stay in the skoolie. I will not enjoy my time relaxing if I'm looking out for my 1000$ battery :0
