Old 12-15-2015, 10:00 PM   #11
Coachwork: AmTran (International)
Chassis: Gensis
Rated Cap: 74
power converter/charger
What do you think of Progressive Dynamic PD4060KV RV Inteli-Power 4000 Series Power Center 60A ?
slager55 is offline   Reply With Quote
Old 12-15-2015, 10:15 PM   #12
Engine: 5.9 Cummins, Allison 545
here i am installing a similar panel in my bus
http://www.skoolie.net/forums/f27/bo...html#post78993
too many wires in too small a space. i hate it... its a cheapo plastic case. and i bypassed 4 or 5 circuits just because its a pita. those 4 or 5 got their own fuse wired straight to the battery. to this day i still havent been able to tuck those wires in so that i can put the cover back on it.
Turfmobile Build Thread
Old 12-15-2015, 10:37 PM   #13
roach711's Avatar
Rated Cap: 19
The 4060 power panel has a little higher charging capacity (60 vs 45 amp) and a 1000 watt input vs 750 for the 4045. Which one you choose depends on how much juice you'll be using.
Turf - I wired mine from the back and had no trouble at all. I'd buy another one without hesitation.
Old 12-15-2015, 10:52 PM   #14
maybe so, my inexperience cause many of my difficulties
you know i used big fat 10g wire for the DC circuits to avoid voltage loss, and the circuit board was just to flimsy for the heavy gauge wire. i would have had better luck with smaller wire, or more patience
Old 12-16-2015, 12:14 AM   #15
roach711's Avatar
Rated Cap: 19
My Progressive Dynamics panel had wiring pigtails exiting out the back of the unit that made connecting the various circuits easy. If yours didn't have those pigtails then hooking everything up would be quite a hassle. There's not a lot of room to work in those small panels.
10 ga may be oversized, but you'll never overload it.
Old 12-16-2015, 09:45 AM   #16
Chassis: MVP
Engine: CAT 3116
If you want 50A AC service, I would think that the 4500 series would serve you better as it supports a 50 Amp service connection.
All-in-One 240V, 50 Amp AC/DC Power Distribution Panel
Amazon lists the 4590 for $397, but you can find it cheaper here:
PD4590 50 Amp Power Center with 90 Amp Converter/Charger
Piersg is offline   Reply With Quote
