Old 07-25-2017, 05:39 PM   #1
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Power Supply
SCORE! Amazon had this for sale at $403.29 + $49.40 S&H, but it wouldn't be available until the end of the month if I ordered it today.
I called Pierce RV Supercenter, which has one store local and asked their parts department. SURPRISE! They have one in stock (actually more) for $366.92 (no sales tax) and they'll hold it for me to pick up, no shipping or handling involved.
Hmmmm. Which one to purchase?
Old 07-25-2017, 06:00 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
what are specs? looks pricey. quick ebay search found 45 amp unit $171 delivered
WFCO 45 AMP RV POWER CONVERTER CHARGER WITH DISTRIBUTION PANEL WF8945ANP
link
The 8900 Series has revolutionized RV Power Centers with it's lighter weight, decorative doors, and superior features. 8900 Series models provide a clean, constant 13.6 VDC output for reliable operation of electronics and appliances.
Automatic three-stage charging maintains the life of your battery with output voltages of 13.2 VDC "sleep" mode, 13.6 VDC nominal charge, and a 14.4 VDC " boost " charge. 8900 Series models also maintain peace and quiet, as the cooling fan runs only when needed. When the fan is running, it is so quiet it goes unnoticed.
FCC Class B approval for every power center model means the units do not cause interference with tv's, radios, and other signals. Electronic current limiting automatically shuts down power during overload or short circuit conditions, protecting the life of your power center and electrical system.
8900 Series models provide AC/DC distribution with innovative features. They can accommodate a 30-amp main AC circuit breaker and up to five branch circuits. Eleven-branch DC circuits are available with LED bulbs for each DC circuit to illuminate and identify open circuits .
Old 07-25-2017, 07:00 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
DC Output: 55 Amps
AC Input: 120/240 Volts
8 AC Branches
15 DC Fuse Locations
Series brings output amperages to 50 amp shore services that have never been seen before. The 5355 is a 50 Amp Power Center with a three current stage 55 Amp Converter Charger. Manufactured to operate on 120VAC 15 amp branch circuits leaving plenty of power for running other 120VAC devices. The unit is built with a durable steel enclosure and has an 15 position fuse block with blown fuse indicators. Can be upgraded to TempAssure™ technology by installing the Parallax 4400TAU module to maximize battery charging.
Specifications
Amps:
55 amp
Listed:
ETL Listed
Special Features:
50 Amp Shore service; 15 Position fuse block with blown fuse indicators; TempAssure option ready; durable steel enclosure
Series:
5300 Series
Temperature Compensation:
Capable
Type:
Power Center
Upgradeable:
Yes with the 4400TAU
Old 07-27-2017, 03:57 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Got the power supply today. Also got a 50 amp cord & plug. Darned cord cost almost as much as the power supply!
