Old 09-09-2018, 09:55 PM   #1
Frochevy's Avatar
Chassis: Collins
Engine: 6.6L LMM Duramax
Propane Generator?
Hello
I'm planning on building a rear platform on my short bus. I want to build it large enough to house a generator. Any thoughts or advice on platform size would be greatly appreciated also. Im thinking same width as bus (8') and a length of 24-32"... So that gets me looking at generators to how how large to build the rear platform. The bus will be used for tailgating (already is) and then be full rv conversion long term. I was leaning toward a cheaper harbor freight 3500 watt invertor generator. Then I saw a duel fuel champion generator. I plan on having propane on board for hot water heater, heater, etc. Any one use one of these? I would like to stay under 60db or around there so it's fairly quiet for tailgating. Are there any other propane quiet generators out there? I just thought it would be nice not to have to lug gasoline around. (Bus is diesel)
Here is a link of the champion generator I was looking at.
https://www.amazon.com/gp/aw/d/B01FAWMMEY/ref=cm_cr_othr_mb_bdcrb_top?ie=UTF8#cm_cr_carousel _images_section
Frochevy is offline   Reply With Quote
Old 09-09-2018, 10:15 PM   #2
I've been looking at this one with wireless remote control.
https://www.championpowerequipment.c...tart-inverter/
Old 09-09-2018, 10:31 PM   #3
joeblack5's Avatar
Year: 98
i use a DuroMac Sidekick 200 watt Duel fuel Inverter. So far so good.
Later J
Old 09-09-2018, 10:35 PM   #4
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
Originally Posted by Frochevy View Post
Hello
https://www.amazon.com/gp/aw/d/B01FA...images_section
I have that generator. However, I haven't even had a chance to fire it up yet. I'll be using it to run my rooftop a/c. I'll be using the propane option and putting either a hard start or soft start capacitor on the a/c if it can't handle it.
Nick
Ninjakitty is online now   Reply With Quote
Old 09-09-2018, 10:42 PM   #5
Fire it up and take a video, are they as quiet as they claim (56db)? That's pretty quiet considering.
Old 09-09-2018, 10:42 PM   #6
Ninjakitty's Avatar
I'll put it on my to.do list for this week.
Nick
Old 09-09-2018, 10:54 PM   #7
Frochevy's Avatar
Chassis: Collins
Thanks! Please let me know how it runs your ac! I won't be buying a generator for another month or two. Don't plan to need it until next summer. For now we have a little 2200 watt Ryobi for tailgating. It runs the dish and tv and /or electric skillet at our tailgates. Looking forward I'll need something bigger to run an AC.
Old 09-09-2018, 11:18 PM   #8
Elliot Naess's Avatar
Engine: 5,9 Cummins
Yeehah -- I want in on this information. We use a Honda EU7000 and I would love to convert it to propane.
Elliot
Old 09-10-2018, 01:33 AM   #9
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
I converted my gasoline Champion 46540 generator to propane a few years ago, using an Impco kit that has a Garretson KN demand regulator. The generator now always starts on the third pull, never the second or fourth, unlike when it was running off gasoline when it would always start on the first pull. It takes the extra two pulls now to draw the propane through the extra hose to the demand regulator and on to the original carb - no big deal. I think it runs slightly quieter now than before, the exhaust is absolutely clear but with slightly more water dripping out than before, and it seems to make power no differently than before, i.e. whatever it could run before it can still run now. All in all, it was well worth the change. The gasoline tank and carb are still in place, so I could run it on gasoline if I wanted, but why would I?
I anticipate only needing to use my generator a few times a year, at most, so it makes sense to run it off propane instead of risking the carb getting gummed up due to lack of use. It's only for emergencies such as when the sun hasn't shone for a few days and the batteries are getting low, but on those rare occasions it MUST start without fail.
Old 09-10-2018, 01:36 AM   #10
Ninjakitty's Avatar
Check out motorsnorkel.com. They make conversion kits for almost every gas generator
Nick
