Old 02-02-2019, 10:19 AM   #1
tincaneasybakeoven's Avatar
Year: 95
Coachwork: Amtran ss-33
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
pulled most wiring unvolved with door interlock no start
95 amgen33 lnt 444e 3800
Prior manufactured 1992 vin confirmed
Pulling all wiring not needed for r.v. use
I.e speaker flashing red , flashing yellow, strobe, interlock, rear heater,
After removal i have a no start condition
Although i do hear a solenoid clicking on the firewall near the left foot when using a key to start.
What did i do wrong?
Thanks in advance!
tincaneasybakeoven is offline   Reply With Quote
Old 02-02-2019, 10:30 AM   #2
Sounds like you didn't do your homework before jumping in.
So much has been written in these forums of this problem that the answer is in those threads.
BlackJohn is online now   Reply With Quote
Old 02-02-2019, 11:38 AM   #3
sounds like you accidentilly cut an interlock wire that needs to be connected to work..
if you still have the parts that you took off you can look at the interlock switched to get the wire colors that were the interlock..
then you can find the stub of the harness where you cut the wiring out, look for those colors and trace those wires back.. or if you can find both wires, connect them back together..
the biggest thing causing no start would be if there was a Vandal Lock on the back emergency door.. that lock was designed to be Locked only if the bus is not in use.. for keeping robbers out..
when the bus is in use the back door must be unlocked.. so if you removed a vandalock device that would be a good place to start.. to look at the wiring that went to it and see if you can find it at the other end..
on some of the AmTran busses, they provide a wiring diagram on the inside of the electrical panel door.. if yours is new enough it may have an outside electrical access door.. otherwise it may be inside the dashboard switch panel.
the wiring associated with the school lights shouldnt affect the starter interlock
you can also check the wiring associated with the roof hatch if you removed it.. on one of my busses the roof hatch open just makes a loud buzzer.. on the other the starter is disabled if the hatch is swung open or not closed tight.
Old 02-04-2019, 10:41 AM   #4
weboughtabus's Avatar
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
I seem to recall someone on here having an issue with starting after they disconnected their stop sign, so it may be something that seems unrelated.
charlotte_thebus on Instagram
weboughtabus is offline   Reply With Quote
