Old 08-05-2018, 10:48 PM   #1
trinitysj's Avatar
Chassis: TCFE2000
Engine: 5.9L Cummings 12v
Question about battery hookup
I think I did this right.. The primary question is the battery config?
It is all working as expected however I just want to make sure that the battery connections are correct for the panel and the inverter. placement of positive and negative cables.
trinitysj is offline   Reply With Quote
Old 08-05-2018, 11:06 PM   #2
Coachwork: Amtrans
Chassis: Genesis
Rated Cap: 20 (9 window handicap)
Just curious, i assume your 50 amp panel has two different hot legs, does your inverter power both legs or just one leg?
On my 30 amp setup i have two seperate sides on my ac panel, and one side is only powered by shore/gen, and the otherside is either shore/gen or inverter based transfer switch. This way i put the dc converter and my ac unit on the side that only works on shore/gen so i wont have to worry about the inverter trying to run the ac or batter charger.
Tigerman67 is offline   Reply With Quote
Old 08-06-2018, 09:50 AM   #3
trinitysj's Avatar
Chassis: TCFE2000
My panel and Transfer switch have 2 hot legs on them. 1-Red, 1-Black
The inverter powers the generator side of the transfer switch and then jumpers to the other side to provide power to both sides of the panel.
Old 08-06-2018, 10:06 AM   #4
trinitysj's Avatar
Chassis: TCFE2000
Here is an updated diagram
Old 08-06-2018, 12:41 PM   #5
Coachwork: Amtrans
Chassis: Genesis
Looks good in my opinion. My only caveat is to make sure you dont have your dc converter running while on inverter.
Old 08-06-2018, 12:44 PM   #6
trinitysj's Avatar
Chassis: TCFE2000
That is the bottom breaker in my panel and it can be switched off when on the inverter.. that's how we do it
Old 08-06-2018, 03:51 PM   #7
trinitysj's Avatar
Chassis: TCFE2000
Im still not sure i got an actual answer.
specifically, if I have four batteries, do i connect the positive from the first one and the negative from the last one to the inverter.. or do i connect the positive and negative from the first OR last one to the inverter?
thanks
Old 08-06-2018, 05:12 PM   #8
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I'm not sure I understand what you are doing. I think you are planing to have one shore power cord that is plugged into either a pedestal or generator. Correct?
It might be helpful if you labeled the wires/colors. It appears that you have both legs (hot - of the 50 amp circuit) going to a single panel? Correct? Is this a split panel where half of the breakers are powered from one leg and the other half from the second leg?
Battery wiring depends battery voltage, battery count, and desired output. I assume you want a 12V bank, as that is typical. Also assume you are using 12V batteries. Hopefully this helps:
JD - Full timer out west
My Adventures & Build
Old 08-06-2018, 07:14 PM   #9
trinitysj's Avatar
Chassis: TCFE2000
Originally Posted by JDOnTheGo View Post
I'm not sure I understand what you are doing. I think you are planing to have one shore power cord that is plugged into either a pedestal or generator. Correct? It might be helpful if you labeled the wires/colors. It appears that you have both legs (hot - of the 50 amp circuit) going to a single panel? Correct? Is this a split panel where half of the breakers are powered from one leg and the other half from the second leg?
That is correct. It is a 50A Progressive Dynamics panel which has a two pole 50A breaker in the middle that powers both halves of the panel. Then there is a a 12v panel on the right side for all of the 12v stuff. And a charge conrtoller in the bottom.
I added a new image to help too...
Old 08-06-2018, 07:33 PM   #10
There's been some posts lately about balancing battery size with inverter size. I'm pretty much a moron when it comes to electrical (I just want to know what's tried-and-true for other people and copy their system!) but something about internal resistance inside a battery and it not being workable with too big of an inverter.
Here's a link that discusses it in detail: https://www.solarpaneltalk.com/forum...-size-tutorial
Old 08-07-2018, 05:20 AM   #11
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Ok, the specific equipment helps - as does the wire color key. I assume the PD4500.
It appears you are jumpering the two legs together when on inverter power. That is fine as long as you understand that you are responsible for power management. Going from 100 amps (110VAC) down to whatever the inverter will provide (25 amps, max) requires some human involvement. For example, the battery charger is typically on a circuit that is not powered from the inverter. Obviously, charging the battery from the inverter would not work very well.
As Drew points out, a 3500 watt inverter is oversize for a 12VDC battery bank. It will work but you can damage your battery bank pretty easily if you run it very hard (near max output). The referenced article is very good. Just another thing to manage which is certainly not hard but part of living 'off-grid'.
I think the 'Battery Bank 2 @ 140 Ah' label plus what you've said above means that you have four, 12VDC batteries that are each 140 Ah. So, you have a "house" battery bank that has a total capacity of 560Ah and 280 Ah usable. Correct?
I realize we are fairly high level at this point but please do plan a good battery monitor (like this) to keep track of your system and take care of your investment.
Old 08-07-2018, 08:57 AM   #12
trinitysj's Avatar
Chassis: TCFE2000
I have the Progeressive Dynamics PD4560 Panel to be specific.
Old 11-04-2018, 07:00 PM   #13
Year: 1987
Coachwork: Can't Remember
Chassis: International s1700
Engine: Navistar/International 7.3L (I think)
Does this apply equally to lifepo4 or ev batteries?
RiskGoals is offline   Reply With Quote
