Old 02-03-2018, 03:48 PM   #11
Robin97396's Avatar
Congratulations! You're going to become somewhat of an expert on the interlock system on your particular bus.
It's not uncommon for interlock issues to pop up two or three times a week on this site. As you can see it happens quite innocently. This is like the Monopoly "Go to Jail and do not collect $200" card. The problem is even two buses of the same model and year will often have dissimilar wiring of the interlock system. Just to make it fun I guess. They're all similar in theory, but usually have subtle wiring differences so it's not easy to instruct someone about how to fix it. It's not that hard, but it's definitely a learning experience.
Robin
Nobody's Business
Old 02-03-2018, 04:00 PM   #12
Engine: 7.3L T444 Navistar Diesel Automatic
Originally Posted by codym View Post
So I removed the wheelchair lift out of my 1994 Blue Bird TC2000 and now the bus won't start. It cranks but won't turn over. Has anyone had this problem? What do I do?
I had an interlock issue on my rear emergency door. Funny thing is it even had a little sign on the door identifying it as an interlock door.
Yet after I disconnected and couldn't start the bus, I freaked out for about two hours. Lessons hard learned never go away. I fixed it by replacing the parts that I had removed. I understand that you aren't able to do that at this point.
The only difference that I can tell between your situation and mine is that when I attempted to start the bus I only got a loud clunking sound from the control panel to the left of the driver's seat.
The motor didn't engage at all.
You may have more going on then just an interlock, but lord knows I'm no expert.
Also, an interlock is usually just a pressure switch that closes a circuit. Potentially, if you could track down the wires that were connected to the interlock and connect them together, it should bypass the system until you can lock down the specific relay to remove.
Interestingly, I also have a wheelchair lift but it does not have an interlock at all. It's on the side door and I have already disconnected the wiring to it.
mikej42 is offline   Reply With Quote
Old 02-03-2018, 08:42 PM   #13
Year: 1994
Here's a video. It may not apply to your specific bus, but may be helpful.
I hope its this easy! I will try it and get back to you all!
codym is offline   Reply With Quote
blue bird, relays, tc2000, wheelchair lift, wiring
