Old 06-04-2017, 10:21 AM   #1
Removing headlight switch?
My headlight switch is loose and flopping around in it's dash position. Was that way when i bought the bus. The seller told me that the headlights flicker off and on. They replaced the dimmer switch. Am i wrong to think that the switch must mount tightly so as to ground. You can turn and turn either way and it never releases or tightens up.How do i remove it?
Old 06-04-2017, 04:21 PM   #2
Rated Cap: 42
If it's like mine, there is a button on the housing behind the dash. Took a little while to find it. Push that and the switch plunger comes right out. It took a little bit of coaxing and holding my tongue right.
Sent from my MotoG3 using Tapatalk
ghodges is offline   Reply With Quote
Old 06-04-2017, 04:40 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Pretty much every switch that has a pull knob made since the 50s has a release like this on the switch behind the dash. Take all of your jewelry off and feel around for a button that looks something like this.
push it and the knob will come out. Then turn the chrome bezel. Be aware that this will also turn on the lights. I guess I should have told you to unhook the battery. I never do but I have done this a few thousand times.
All you have to do is push the knob back in and it will catch.
Old 06-04-2017, 07:38 PM   #4
Some are removed this way some not. If no button on the back try pulling out (Giggity), twisting the knob & remove it.
BigDavid is offline   Reply With Quote
Old 07-05-2017, 02:52 PM   #5
All i haD TO DO WAS PUSH IN THE BUTTON AND REMOVE THE ROD. sLOTTED SCREW DRIVER TO UNSCREW THE BEZEL.. dan caps sorry.
Put in a new switch and still no headlights. When i pulled out the switch rod to turn on headlights i would get a head light flicker but not now. I guess it is ime o start checking grounds.
Old 04-10-2018, 02:51 PM   #6
Did you ever find a solution to your problem? It seems I’m having the same issue in a 93 International
fhazie is offline   Reply With Quote
