Old 09-12-2019, 07:59 PM   #1
Right or needs fixing?
I am uploading a picture of how I *think* the electrical system for my from scratch electrical system should work. I am a total electrical newbie. I will NOT be installing it myself - someone who knows what they are doing will do that. But I do want to be sure to know what they should be doing. Also want to know how it's all set up should I need electrical help on the road.
My electrical diagram is a bit unusual for a skoolie so here's some info of my electrical needs.
I need electricity every day. I have a CPAP and an electric handcycle that attaches to my wheelchair and has a big lithium battery. If it's cold I also need heat.
I need power to these every single day whether I am on shore power or boondocking.
I hope to be able to boondock for 2 weeks at a time. I am assuming that I will want a generator to power the house battery bank (800+ lithium) (yes I know it's the price of a small car).
I am also assuming that solar will not be able to meet my minimum requirement of absolutely have power every day.
I am very grateful to JD who provided the diagram on his website. I adapted it based on what looks right to me.
Please feel free to tell me what's wrong with it. This type of drawing is what I will be working from with the electrical person on. I want to get it right before I talk to them.
Thank you for reading and commenting.
CorbettO is offline   Reply With Quote
Old 09-13-2019, 08:57 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Just a few observations and my opinion. Unless you are going to have a huge generator you won't get two 50A legs. A 3000-3500 watt inverter type with one 30A leg should power what you have listed here.
I'm going to get jumped on for this. Unless you are going to run something like a Tesla lithium I wouldn't do all of that 24-12 volt conversion stuff. Just run it on 12V it takes larger wires to be done properly but, you have a LOT of converting going on there. Every time you convert electricity to something else you loose a bit. Why have 12 and 24 volt lights? RV water pumps aren't generally available in 24V.
If you buy a quality inverter/charger the automatic transfer switch is built in. The latest "hybrid" ones will, if your shore power isn't good enough, draw power from your battery bank to make up the difference. When the load decreases they will then resume battery charging.
Not sure what the "high/low voltage inverter" you have listed are.
Old 09-13-2019, 03:56 PM   #3
With a 24v battery bank the only dc-dc converter that I will need is for my heater. All other DC loads are 24v.
There is a definite advantage to running a 24v or 48v house battery on larger systems.
Old 09-13-2019, 08:37 PM   #4
Chassis: Front Engine
I didn’t go in great detail but it looks like the generator powers an inverter which ties into generator output power too? That’s bad if that’s the case. You can’t ordinarily mix ac power sources because they’re not in phase and the waveforms won’t line up. I agree that a built in transfer switch on the inverter seems best, and may resolve that issue.
rffffffff is offline   Reply With Quote
electrical, generator, lithium battery
