Old 04-02-2018, 04:46 PM   #1
Romex vs Stranded
Anybody using Stranded copper for their 120v applications?
~Dilly
www.saoirsebusblog.com
dilly@saoirsebus.com
Dilly is offline   Reply With Quote
Old 04-02-2018, 05:00 PM   #2
I have used a stranded wire very similar to Romex. I can't remember what the proper designation is. We called it "boat cable"
Many RV manufacturers use Romex which is solid.
Old 04-02-2018, 05:17 PM   #3
I have seen a bunch of builds with Romex and blown-in insulation. Do you think they will chafe over time from the bus movement.
~Dilly
Old 04-02-2018, 05:46 PM   #4
Blown in OR spray foam insulation?
Old 04-02-2018, 05:51 PM   #5
spray foam
~Dilly
Old 04-02-2018, 06:18 PM   #6
Chassis: Saf-T-Liner MVP ER
Thomas used Romex for the heaters. They still work 18 years later. I'll use it for the 120V circuits.
Steve Bracken
Build Thread
Old 04-02-2018, 06:25 PM   #7
Originally Posted by Dilly View Post
spray foam
Then I would not worry about chaffing where it is encapsulated in the foam.
Chaffing generally occurs when the wire is allowed to move against a rough or sharp surface.
The foam will secure the wire in place.
Old 04-02-2018, 08:06 PM   #8
thanks guys
~Dilly
Old 04-02-2018, 09:46 PM   #9
Is using spray foam on long runs of wires as anchor points every interval or so a reasonable idea?
Old 04-03-2018, 10:30 AM   #10
Chassis: B3800 Short bus
Really? Not in my Thomas they didn't. The original heater wiring in mine used what I've always referred to as boat wire. Either 12/3 or 12/4.. I can't remember. It looks like this:
