Old 08-01-2018, 02:52 PM   #1
druidwood's Avatar
Chassis: TC 2000
Engine: 5.9 L Cummins Turbo
Rated Cap: 28
running lights and how to wire DC
So my running lights worked, then I had to cut the line to reroute for ceiling and now they don't. I know my connections are good and had whole wire exposed so no cuts. Wondering if my problem is that DC needs to be "chained?" i.e. I put both side lights, incoming and continuing line in one join, but notice the front and back have them one at a time. Do you need to run one side with incoming/outgoing and then a couple inches down do the same for the other side? Thank you.
druidwood is offline   Reply With Quote
Old 03-14-2019, 01:44 PM   #2
ultrapac's Avatar
Chassis: tc2000
Engine: cummins 5.9
did you ever figure anything out?
ultrapac is offline   Reply With Quote
Old 03-15-2019, 10:06 AM   #3
druidwood's Avatar
Chassis: TC 2000
Rated Cap: 28
Thanks for asking. Yes I had wired everything just fine - only ever having driven the bus once forgot there is a switch for the running lights. Not my only "doi" moment.
If I ever can get back to this now abandoned project will have lots of other things to figure out.
dc wiring, running lights
