Old 06-01-2017, 09:07 AM   #1
Engine: 5.9 Diesel Cummins
RV Power center vs. House Breaker box & separate 12 volt box/ charger/ etc.
So, before I really dig into my rebuild (i have the ceiling half done, AC installed (not wired), etc.) I'm trying to make sure i'm moving forward "wisely."
Obviously, I can install an RV power center (like a WFCO or the like) that would combine my 12 volt and 110 AND battery charger into one box. But, i'm reading things about those not being the best/ most efficient chargers, etc. I'm just wondering what peoples thoughts are. I don't need to have everything "the best" in my skoolie conversion (we will mostly camp and not do a TON of boondocking)... but I also don't want to have to "redo" anything because of lack of quality.
SO, i'm wondering what people have done and why they chose to go the route they went. Did you "piece" your power system together or buy an "all in one" power center.
lanegordon is offline   Reply With Quote
Old 06-01-2017, 09:39 AM   #2
jpm9909's Avatar
Chassis: Thomas 140HS 84 pass
Engine: RE 5.9L ER6BTA230 w/ MT643 Trans
commenting to follow... (great question)
"Be kind, for everyone you meet is fighting a hard battle."
jpm9909 is offline   Reply With Quote
Old 06-01-2017, 11:07 AM   #3
roach711's Avatar
Rated Cap: 19
I went with one of the Progressive Dynamics power panels and am quite happy with it. I have all my fuses and breakers in one small package along with a three stage charger.
From what I read the PD charger was one of the better ones when I bought it 5 years ago.
The Roach Motel
Old 06-01-2017, 11:07 AM   #4
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Following
Old 06-02-2017, 01:35 PM   #5
Engine: T444e
Rated Cap: 35
I am looking at using the Progressive Dynamics 4000 series just to simplify and keep things in one easy to access package.
bstewrat3 is offline   Reply With Quote
Old 06-02-2017, 03:02 PM   #6
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I suspect these decisions often come down to how much your know about electricity, how much you want to learn, and how much you want to customize. I see nothing wrong with one of the power centers as long as it meets your needs.
I built my own "system" and it is fairly large and complex (details here) but I like electronics and put 1.7kW of solar and 10kWh of lithium batteries in as well. The goal being loads of boondocking.
IMO, the best approach is to define your mission/goal and then settle on a system that meets that goal.
JD - Full timer out west
My Adventures & Build
