Closed Thread
Old 08-31-2015, 10:59 AM   #11
use the main breaker on the power pole at campsite
from there your power cable will connect to your inputs (circled above in red)
take your "double" breakers and they clip into/on the aluminum stand offs
Pick up 3 half size double breakers
I used 15 amp breakers because I used 12 ga wire and it's good for 20 amps so I undersized breaker
bansil is offline
Old 08-31-2015, 11:04 AM   #12
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
I need to put some kind of main breaker so that I don't accidentally take 30A off a 15A house cable. Maybe I need a second breaker box though I thought a 6 breaker box would do it.
Zephod_beeblebrox2 is offline
Old 08-31-2015, 11:13 AM   #13
Well, if your plugged into a house circuit, you will use that breaker as the control breaker, it will only allow 15 amps total from it so you will be good to go
make sure that a fridges and freezers etc are not on it, I only have 2 15 amp receptacles at the house I can use, rest have to much other crap on them
so just like the 30/50 you use the breakers installed to regulate your source
bansil is offline
Old 08-31-2015, 11:17 AM   #14
Year: 1994
Engine: 466dt
Rated Cap: 59
I have a 50A socket with one of each flavor of wire. Do I take the live and put it to hot 1 and 2. When I encounter a 50A supply do I connect the two hots to feed them into my single live wire?
Old 08-31-2015, 11:43 AM   #15
get one of these for less than $10
Mighty Cord RV15AM30AF Park Power Adapter 12" 15M-RV30F
and one of these for less than $20
30Amp Male to 50amp Female RV Cord Dogbone Adapter 12'' | eBay
and a 50 amp cord like this
or a socket
how ever you do this bit
NU-CORD 94552 25-Feet 50-Amp Rv Cord, Loose End - Rakuten.com
I BOUGHT ALL MY STUFF ON AMAZON OR EBAY, LOCAL STORES WILL HAVE IT ALSO
so now connect:
white to neutral bar (isolated bar)
green to ground bar (add on bar attached to metal box)
black to hot
red to hot
this will energize all 6 circuit breakers
on 50 amp service you will have 50 amp or so on one "leg" 3 breakers
and 50 amps on the 2nd "leg" 3 breakers
when you put on the 30 amp to 50 amp adapter, you now have 30 amps divided between all 6 circuit breakers
then when you attach the 15 amp to the 30 amp you will have 15 amps divided between all 6 breakers
disclaimer: this is my thinking and logic and there are other ways to do this, this is easy and quick in my mind
also remember if hooked to 50 amp power you also have a 30 amp available and a couple 15 amps on the pole still for say an outdoor ice maker or TV or music and lights (w/o using your 50 available) I never said I was green
also hard wiring only works if you have a place to store the cable, if not then you will need a socket and matching plug to put on your cable
underbelly bins work good for cable storage
I just have a 40# cord I pull out every time
bansil is offline
Old 08-31-2015, 12:50 PM   #16
crazycal's Avatar
Much of what passes for code in the US would fail utterly any UK electrical inspection.
Maybe you can ship the bus to England so they could properly wire your bus since it's so screw up here.
I'm hungry!
You Gotta Let Me Fly
crazycal is offline
Old 08-31-2015, 01:12 PM   #17
I just noticed in OP that you have a 50 amp 3 pin plug, that will not work in this instance, you will need to change to a 4 pin/wire setup of stick with just 30 amp service with this plug
check this out
bansil is offline
Old 08-31-2015, 01:30 PM   #18
Engine: 5.9 Cummins, Allison 545
wouldn't a 50amp 3 wire connection hot skin the bus using ground as the neutral?
Turfmobile Build Thread
turf is offline
Old 08-31-2015, 01:39 PM   #19
I think there may of been some confusion, I believe he has a 3 wire plug rated at 50 amps and NOT a 50 amp RV plug
bansil is offline
Old 08-31-2015, 02:20 PM   #20
Chassis: Blue Bird
Engine: ISC 8.3
Originally Posted by Zephod_beeblebrox2 View Post
My outside socket is this.Attachment 8415
This looks like the "NEMA 10-50" style. It's intended to be used with the two angled blades each connected to one 120 volt hot leg and the one straight blade (parallel to the yoke) grounded. I'm really not sure whether this third pin is properly called "ground" or "neutral" but in any case this style isn't appropriate for most new installations. If you need 240 volt service, get a 4-pole connector.
turf has identified the reason why those 3-pole connectors aren't used for split 240 volt (US style) connections anymore. If all's working correctly then no you won't get a hot skin, not by more than a volt or two anyway. But there's no fault protection, either. That's why the ground and neutral are wired separately now.
Where do I put the main breaker? This is a 6 breaker box.
Originally Posted by Timelord View Post
Your breakers don't have to add up to the main breaker. It is all about wire size protection. (Well, that and shocks/shorts.)
You could install a main breaker, and perhaps might to avoid the nuisance of tripping an upstream breaker and having to ask your camping hosts for help finding and resetting it. It isn't necessary though. This is a "sub-panel" and is designed to be wired directly to the supply wires; it's understood a breaker would be installed at the far end of the supply wires to protect them. If you want to have a "main" here too you can; just choose a breaker that is rated for reverse use and connect the incoming supply to its load/output terminal. It could snap into any position in the box, but mark it "MAIN DISCONNECT" since its function won't be obvious once the cover is installed.
Originally Posted by bansil View Post
bansil did a great job identifying the terminals in the box. One thing to check: be sure that the bus bar marked "neutral" doesn't have any electrical connection to the metal housing. Sometimes they do, and in this case any such connection should be broken.
That's good advice. Based on your other threads, it seems your expected electric consumption will be very low, so the traditional TT-30 style plug would be a great choice. Its one hot lead can be wired to both hot bus bars in that panel so that breakers in all positions draw from it.
family wagon is offline
Closed Thread
