Closed Thread
Old 09-01-2015, 01:48 PM   #51
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Originally Posted by crazycal View Post
I see them. Maybe you shoulld switch to Ubuntu now..
Yeah, they're showing now. They weren't earlier
Zephod_beeblebrox2 is offline
Old 09-01-2015, 02:26 PM   #52
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I see them
Captain Obvious on deviantArt
Scooternj is offline
Old 09-01-2015, 06:49 PM   #53
roach711's Avatar
Rated Cap: 19
One....last....try to talk some sense here.
Zaphod, the receptacle on the outside of your bus should be a proper RV male receptacle, not a female. Your female receptacle requires that you build an extension cord with two male ends (a suicide cord). This is a big problem.
Imagine that someone is helping you pack up before the drive home. She (maybe your wife) unplugs the bus end of the extension cord first and begins rolling up the cord. The end she just unplugged is still hot and she touches the male prongs. Imagine the fun things she'll say to you if she survives.
Imagine that some kids (maybe yours) are playing around the back of your bus and one trips on the cord, and since it's not a twist lock plug it unplugs from the bus receptacle and since it's a male plug it's easy to touch the hot prongs. Maybe one of them picks it up, touches the male prongs and gets a shock, just like my niece did. Maybe the grass is wet and both kids are bare footed (and therefore very well grounded). If those male prongs touch the wet grass both kids (as well as anyone else close by standing on that same grass) are going to be badly shocked and quite possibly killed. This is not just theoretical; it happens way too often in real life.
Lets talk about the American legal system. If one of those kids dies and the parent's lawyers find this thread proving you were told your system was dangerous and went ahead anyway you'll be charged with negligent homicide.
Now tell me, would you prefer to take the time and do it right or would it be more fun to live your life knowing someone died because you thought you knew better than everyone else?
roach711 is offline
Old 09-01-2015, 07:06 PM   #54
Year: 1994
Engine: 466dt
Rated Cap: 59
Hmm.. Hadn't considered the exposed live wires. I have thought two 15a standard cords would be cheaper than a single 30 by a large margin.
Old 09-01-2015, 09:57 PM   #55
crazycal's Avatar
Are you trying to prove Darwin's theory?
I'm hungry!
You Gotta Let Me Fly
crazycal is offline
Old 09-01-2015, 10:45 PM   #56
Originally Posted by bansil View Post
keep this in mind
50 amp service is actually 2 110V lines coming in, one will have 25 amps available to use and the other will have 25 amps available (these numbers are for demonstration) . . .
Wrong! The "50-amp" 4-pin 120/240 volt RV outlet has a full 50 amps available on each hot leg. If you are using only 120-volt appliances, and you wire the bus to carefully divide the loads half on one hot leg to neutral, and half on the other leg to neutral, you have a total of 100 amps available at 120 volts. Either way, there are 12,000 watts available, either 50A x 240V or 100A x 120V, or some lesser combination of the two.
If the campground is mis-wired, and both hot pins are on the same supply leg, then you have zero volts at the 240-volt appliances, 50 amps on each hot leg, and 100 amps on the overloaded neutral wire rated for only 50 amps.
If both the outlet and bus are correctly wired for 120/240, then the neutral only carries the difference in current between the draws of the two hot legs. If you have a 1200 watt, 120-volt heater runing on one hot leg (10 amps), and a 60-watt light bulb running on the other (1/2 amp), then 1/2 amp from the heater continues through the light bulb to the opposite leg, and the 9-1/2 amps difference current from the heater returns through the neutral.
The 30 amp, 120-volt only RV outlet is only capable of 3600 watts. It has one hot, the neutral, and the safety ground.
The 3-prong outlet in ZB's photos may be an older 120/240-volt cookstove plug with no safety ground. In Grandpa's day, installers ran a separate safety ground wire from the case of an appliance to a nearby metal water pipe. It instead may be a 240-volt only cord with two hots and a safety ground, and no neutral. If so, there would be no 120-volts available for New World appliances.
Back in the old country, there is no neutral, and no 120-volt half voltage available. There are only two hots. That's why all plugs have fuses in them on both wires, and insulation on the back of the pins so you can't have the plug in far enough to connect to the mains and still have metal to touch on the pins of a half plugged in cord.
Redbear is offline
Old 09-01-2015, 10:51 PM   #57
Year: 1994
Engine: 466dt
Rated Cap: 59
I'm looking at this
http://www.electricalmaterialscompan...etered-370.jpg
Is this standard at most RV sites?
I see two sockets that *look* like 110v 15A sockets on the bottom right. Am I correct?
Old 09-01-2015, 11:01 PM   #58
The one on the left is a 4-pin, 120/240 volt 50-amp socket, 12,000 watts.
The one in the middle is a 3-pin, 120 volt 30-amp socket, 3600 watts. Ignore the hole in the middle.
The two on the right accept both 15 amp (blades parallel) or 20-amp (neutral turned 90) cords, 2400 watts between the two.
Each outlet has its own breaker above. The 240-volt breaker is two lines strapped so both hot wires trip off together.
Redbear is offline
Old 09-01-2015, 11:09 PM   #59
Year: 1994
Engine: 466dt
Rated Cap: 59
Are the 15 amp sockets common in paiurs? Just thinking 15a cirds are cheaper than 30a cords
Old 09-01-2015, 11:23 PM   #60
Yes, most 15-amp and 20-amp receptacles are dual.
*BUT*
The 20-amp is the rating for the one cable feeding both outlets.
You cannot safely draw 30 or 40 amps by plugging in two cords into opposite halves of a dual outlet. The draw from the two cords must add up to the outlet rating.
It is a false economy to skimp on extension cords, especially on long runs. All wiring has some resistance, and resistance when current is drawn means heat is generated and power is lost.
My old camper does not have much draw, so I removed the heavy #10 cord with the 30-amp plug and wired in a replacement #12 wire good for 20 amps. Though there are a couple of AC outlets, the cord really only runs the converter to charge the battery, and run the 12-volt lights and 12-volt furnace blowers.
If you go to the hardware store or home center, a lot of the bargain outdoor cords have only #16 wire, which won't even handle 15 amps well. Pick through to find (or build) a #12 or at least #14 cord.
Redbear is offline
Closed Thread
