Closed Thread
Old 08-31-2015, 01:26 AM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Shore power
I have my socket for the side of the bus. It's a 50a 3 pin thing.
I have a breaker box
The plan is to run a 50A cable from the socket to the breaker box in conduit. I have lots of corners to go around so that'll be fun!
I figure I'll have 4 sockets, 2 @ 15a and 2 @ 10a. The main breaker will be changed according to the power supply so 50a where possible, 30a or 15a where applicable.
The 4 sockets will be mounted on the front of the beam under the microwave.
The rest of the bus will be 12v supplied from 2 x 12v 105ah marine batteries.
Thoughts?
Zephod_beeblebrox2 is offline
Old 08-31-2015, 03:10 AM   #2
Engine: 190hp 5.9 Cummins
No one installs 10 amp 120 volt plugs.
I would never install anything less than 15 amp. Most mine will be 20 amp.
nat_ster is offline
Old 08-31-2015, 05:14 AM   #3
Chassis: Genesis
Your breakers don't have to add up to the main breaker. It is all about wire size protection. (Well, that and shocks/shorts.)
Timelord is offline
Old 08-31-2015, 08:12 AM   #4
keep this in mind
50 amp service is actually 2 110V lines coming in, one will have 50 amps available to use and the other will have 50 amps available (these numbers are for demonstration)
I would run a 50 amp cord to a breaker box, have 1 line feed one side of the box and line 2 feed other side, this will allow you to take full advantage of the power when available and needed
I actually have the bus zoned so I have 50 amps to use in the bedroom and kitchen area, and when plugged into 50 amp this allows me to use a second ac or heater in the front area
use basic 15 amp receptacles and breakers from box store (they can be replaced anywhere)
if you pick up a 30 to 50 adapter, and plug your shore cord into it, and then plug into a 30 amp electrical box, this will allow all circuits in the bus to have power, just like when 50 is hooked (now don,t overload it or you will trip the pedestal)
now plug a 15 amp adapter into your 30 amp adapter, this will let you plug into a 110 house circuit and power all outlets (you only will have 15 amps availible to use before you pop breaker though
at the house this is what I do, I can run one AC and a couple lights no problems, if I need to use microwave for heating coffee or something? I turn off AC and use microwave
I have a bunch of pictures in my build with this stuff, and thanks to redbear, I also have 220V to heat my 40 gallon water heater when plugged into 50 amp (remeber 50 amp is 2 110V), and a flip of a switch allows me to use it on 110V
bansil is offline
Old 08-31-2015, 09:32 AM   #5
Year: 1994
Engine: 466dt
Rated Cap: 59
I did hear that 30A was more common at campsites.
Using two wires for 50A seems somewhat of a duct tape fixes everything kludge mind, the whole US electrical system looks like an amateurish kludge to me.
I'm not really sure how this breaker box is going to work or if it's just plain missing bits. I've taken the door and cover off and can't see any way of adding a second live wire. I can't see where the live, neutral and earth wires connect as there seems to be just one connector strip.uploadfromtaptalk1441027714529.jpg
If that lot won't do 50A because of the kludged US electrical system then I guess I'll work with 30A on the 30A circuit. That at least should be just the standard 3 wires.
Old 08-31-2015, 10:22 AM   #6
I'm not really sure how this breaker box is going to work or if it's just plain missing bits. I've taken the door and cover off and can't see any way of adding a second live wire. I can't see where the live, neutral and earth wires connect as there seems to be just one connector strip.Attachment 8414
My outside socket is this.Attachment 8415
what?
first off never connect neutral and ground in your bus, keep them separate
notice the rightside with all the little screws? this is for your neutrals from your receptacles white wire in your 30 amp cord
notice the 2 big screws above and center this is where your hot will go into choose one or the other I would use the left side this will allow 2 double breakers and 4 wires to go to receptacles
as for the clunky duct tape fix...whatever, the reason is they can have every other 30 amp pole using alternating hot leads to distribute power more efficiently
And 220 can use smaller wire to carry the load, and now any campsite built in the last 10 or so years has 50 amp normally
State parks and very old Camp sites may not though
bansil is offline
Old 08-31-2015, 10:35 AM   #7
Since you will only have 1 hot coming in you need to either choose hot 1 or hot 2 connection(hot 2 allows more breakers)
or you could use a jumper between the two (just watch for excess load, you only have 30 amps to use)
and the ground I normally just get a strip connector and use it (similar to the neutral bar)
bansil is offline
Old 08-31-2015, 10:42 AM   #8
Of course I had to see what Kludge meant
A kludge (or kluge) (/klʌdʒ/, /kluːʒ/, /kluːdʒ/) is a workaround or quick-and-dirty solution that is clumsy, inelegant, difficult to extend and hard to maintain, yet an effective and quick solution to a problem. It is a rough synonym to the term "jury rig." This term is used in diverse fields such as computer science, aerospace engineering, internet slang and evolutionary neuroscience.
What in the world are you associating with this?
Using 50 amp power????
or not knowing the purpose of 220V and 110V and how they work together???
bansil is offline
Old 08-31-2015, 10:43 AM   #9
Year: 1994
Engine: 466dt
Rated Cap: 59
Where do I put the main breaker? This is a 6 breaker box.
Old 08-31-2015, 10:56 AM   #10
Year: 1994
Engine: 466dt
Rated Cap: 59
The entire US electrical system...
Twisting wires and using wire nuts.... Kooky and dangerous
120v - wasteful because you need heavier cables than you'd need with 240.
Two wires rigged together to provide 220v... Wacky and very wasteful.
Much of what passes for code in the US would fail utterly any UK electrical inspection.
All UK connections between wires are made in insulated junction boxes. All electrical sockets have individual switches. All electrical plugs have individual fuses. All the house circuits go to a breaker box with two lighting circuits - one for upstairs and one for downstairs. Each room has a different breaker for the sockets. Sockets are not permitted in bathrooms or toilets and not within 5 feet of the kitchen sink. Sockets must be between 6 and 18 inches from the ground unless they're over a countertop. All circuits are 13A save for the cooker circuit which us 30A.
Closed Thread
