It's really not THAT complicated but you have to understand electrical stuff a little bit.
In this circumstance you have to find where the wires come from (maybe hard) or just run a new 12V wire to the switch that is on full time (probably easier). It's just a matter of doing the work to get the wire there. finding permanent 12V sources should be easy with a meter, but if you're not up on the electrical side of things it's probably going to be difficult.
maybe that's not helpful but I don't think there's going to be much of a tutorial on this particular item as it seems different on a lot of busses.
Originally Posted by barbaraanne21
I was wondering if you were ever able to figure out the solution to this and make a key work when bus key was not actually in the bus in the on position or turned in accessory position? I need to add a key switch to outside of mine as well because, like you mentioned, keeping key on and/or having to do so very time someone needs to come through the side door is quite bothersome and I can not find out any information to make it happen
