Old 05-27-2019, 12:13 AM   #1
Clayton's Avatar
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
Simple Shore Power System
I'm in the process of wiring my bus. I'm just keeping it simple. For shore power all I will have is 3 plugs in the bus. I plan to run off of 30 amp shore power hook ups. The question is, do I need to have a circuit panel? Or could I just have a GFCI at each plug and wire direct?
Clayton is offline   Reply With Quote
Old 05-27-2019, 01:49 AM   #2
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
you need a breaker so you can shut the complete circuit down - a GF just shuts the breaker in the receptacle off
Old 05-27-2019, 09:18 AM   #3
miltruckman's Avatar
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
The breakers in campground are sometimes sketchy.
And the wire has to be sized for the breaker size. So without your own breakers all of your wire has to be 10 gauge. That would be more expensive than buying a small breaker panel.
miltruckman is offline   Reply With Quote
Old 05-27-2019, 11:28 AM   #4
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
What Sledd said & milktruck said.
Your over-current protection needs to be sized to your wiring, which in turn is sized according to the loads you plan on running. Assuming the common case of 14awg, that's 15A. So what would happen if your loads - through accident or design - drew more? The 30A shore power breaker - if it worked (which is an assumption you don't want to make) - would happily supply it. But your wiring couldn't handle the load. Cue the pretty orange colors.
What you're considering is both dangerous and a code violation.
Old 05-27-2019, 12:13 PM   #5
In my house the GFCI pops, shuts the whole circuit down.
Old 05-27-2019, 12:29 PM   #6
Chassis: CE300
Rated Cap: 23
GFCI outlets have 'line' inputs & 'load' outputs, which allows you to protect the circuit downstream of the outlet if wired in a manner utilizing this functionality. You could also wire them so that they didn't, in which case the circuit downstream wouldn't be impacted.
Regardless, GFCIs do not provide overcurrent protection, nor do they provide a means to manually open the ciruit. They're not circuit breakers (though you can have circuit breakers that also provide GFCI protection).
Old 05-27-2019, 12:45 PM   #7
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
it must be throwing the breaker in your breaker box too - without a breaker box the line would still be hot after the GF disconnected
