Old 03-08-2019, 06:58 PM   #1
Ronnie's Avatar
Engine: 345 international V-8
"soft start" for fridge?
I saw on a post about a/c that there is a device to "soft start" the compressor so start up load is less amps. Has anyone done this with their fridge?
My fridge is a 4.7 cu ft mini fridge. It draws 40 watts or so running,or about 4 amps. Start up is 50 amps 12 volt DC,( not 50 amps 110 AC) at the inverter. I would like to get the start up load down a bit if possible.
Old 03-08-2019, 08:38 PM   #2
sorry not clickableClick image for larger version
Old 03-08-2019, 09:46 PM   #3
Originally Posted by john61ct View Post
sorry not clickableAttachment 30574
Yes it is opens big in a separate screen when clicked.
Old 03-08-2019, 11:25 PM   #4
I'm thinking it works the same way that is used on the "soft start" A/Cs. It reduces power draw, on the compressor, at 1st "grunt."
1olfart is offline   Reply With Quote
Old 03-09-2019, 05:25 AM   #5
Ronnie's Avatar
Thanks typed it in and got it.
How will this work with a fridge? Basically the idea should be just fine, however I assume it(soft start) has capacitors to start the load, so would one for a/c be sized good for a fridge? Seems that it would not?
I have a three phase starter for my milling machine and lathes and it is sized for the motor hp and works great for the correct size motor. For my small mill the motor is too small for the size of the starter so I put a larger motor on the floor to use to balance the load and help create the third phase. I know the phase converter uses capacitors and sizing is important. So with this thinking in mind I am wondering if the same rules apply to the fridge?
Old 03-09-2019, 11:15 AM   #6
a hard start capacitor for a small window unit or a PTAC might very well work..
Old 03-09-2019, 01:08 PM   #7
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Maybe research/try a 3 in 1 capacitor's that are made for fridges.
Old 03-09-2019, 07:57 PM   #8
Ronnie's Avatar
Looked up hard start capacitors, and it seems that should work, so will order one and try it out. Might just try it on a small window a/c unit just in case I goof and fry something. Have an old one laying around, better that then my fridge. Then put it on the fridge once I am sure of what I am doing.
Thanks fellows
