Old 06-20-2019, 02:06 PM   #1
Solar Connection
So I have a red and black lead to go to the charge controller. I notice the short leads are a different wire than the others. How do I make the leads longer without soldering more wire on?
Old 06-20-2019, 02:50 PM   #2
Don't solder anything, crimp, those are standard MC4 connections.
Throw the stub away and crimp new MC4s on the end of the required length you measure what you need.
Old 06-20-2019, 03:36 PM   #3
I need a bare end to go into the CC. One set had long wires, so I cut the connectors off and fed them through the gland and the roof.
Old 06-20-2019, 03:40 PM   #4
I would recommend some chafing protection for the conductors at the roof penetration.
Old 06-20-2019, 03:49 PM   #5
Thanks for the vote of confidence. You mean something like this chafe preventer? The grommet will get sealed when I seal the gland down.
Old 06-20-2019, 04:41 PM   #6
What size wires are those? You could crimp ring terminals on, use SS nut and bolts with blue Loctite and then rubber tape wrapped and covered then by a tight electrical wrap tape. This would allow you to remove the panel or the wire if need be.
Old 06-20-2019, 05:01 PM   #7
They are 10g. Again, you are making something quite easy very complicated. Why not do what I've already done, and then strip 1/4 off the end and secure in the CC the proper way? The panels unplug for removal.
Old 06-20-2019, 06:03 PM   #8
Maybe it's the way you present your questions? Did not know they unplugged.
Half the time I haven't got a clue for what you are doing as in posting the gland picture in the threes for the minisplit. Get with it!
Old 06-20-2019, 06:08 PM   #9
They don't plug into the CC.
I'm confused? I posted the gland pic here in the Solar Connection thread. Where are the Mini-Split pics?
