Old 10-04-2019, 01:18 PM   #1
Solar Monitor
What are we using to monitor solar output and battery monitor. No info screen on my Victron to tell me how much power I'm generating.
Old 10-04-2019, 01:23 PM   #2
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
I use Simarine Pico. Click image for larger version
ID:	38197Click image for larger version
ID:	38196Click image for larger version
ID:	38195Click image for larger version
ID:	38194Click image for larger version
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 10-04-2019, 02:32 PM   #3
Victron BMV, 712 is best.
Bogart Trimetric
Link Pro
Balmar SG-200
For lead banks, SoC% and voltage only, not a coulometer, Merlin SmartGauge is most accurate.
Go here https://marinehowto.com And CTRL-F for battery monitor and read closely those three articles
___
Note if you just want info about the SC contribution you don't want a full bank monitor, just a cheap one way coulometer at the SC output will do.
With the Victron MPPT SmartSolar units, the app on your smartphone is maybe enough. With the BlueSolar line you need the add-on dongle.
Old 10-04-2019, 02:34 PM   #4
Simarine is a fantastic everything-monitor, but its SoC guesstimation is less accurate than the ones I reco'd.
Getting better as firmware updates are published though, and close enough for most, as long as you keep up with the 100% SoC resets.
Old 10-04-2019, 02:40 PM   #5
Bogart SC-2030
- Bogart Engineering
Old 10-04-2019, 03:23 PM   #6
Bogart SC-2030
Actually SC is the solar controller add-on only, he's already using Victron for that.
The Trimetric BM brains model# is TM-2030
Agree using both together is a great combo, for those starting from scratch.
Old 10-04-2019, 04:15 PM   #7
You are right. I have the TM-2030 and keep calling it by the wrong model number. At least I had the link correct
Old 10-05-2019, 03:33 PM   #8
I forgot I had this in my box of bus stuff.
https://www.droking.com/Digital-Test...scription=true
