Old 08-10-2007, 10:21 PM   #1
swinada's Avatar
Solar Vents
Did anybody try out solar vents on a bus/RV yet?
you can get them on e-bay for about $25
or at costco for around $110Can, it makes me think that the costco brands must be a better quality then the e-bay one.
Did anybody try any of those solar vents yet? What kind of experiences did you have?
I'm wondering if they can be closed so that when you drive down the road in rain the water isnt entering the bus.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 09-20-2009, 08:05 AM   #2
blkjak's Avatar
Year: 2005
Coachwork: ford
Chassis: ford
Engine: v8 gas
Rated Cap: 1
Re: Solar Vents
hi -
i am trying to find a top quality roof solar vent that will reverse and have it's own small batteries for night time and gloomy day operation.
blkjak -
blkjak is offline   Reply With Quote
Old 09-20-2009, 09:13 AM   #3
Re: Solar Vents
Swinada, look at the listing - the eBay units fit over a 3" hole. Judging from the photo, they appear to have 8 cells in the array, so I suspect it has a small ~5-volt computer-type fan inside. They are probably in "always on" configuration. When the sun shines, they exhaust. I wouldn't be at all afraid to try a couple, but I wouldn't expect the motors to last over 5 years. The flanged mounting would be easy to attach to a flat section of skoolie roof (if there is such a thing). A pair or 4 of them might insure air flow without a load on the electrical system.
I couldn't find the Costco units you pictured. I did see an attic exhaust with 38-volt motor and thermostatic off control for CDN $400. I think its a heavier-duty construction, and the photo shows them on flashing mounted into a shingled roof. Skoolie mounting may take some Skoolie ingenuity.
blkjck, making a reversing vent would probably require hacking the wiring. DC motors are known to run backward with reverse voltage, so a double-pole, double throw switch would probably do it. BUT (I know wiring but I'm not a pro on the inner workings of electric motors) I suspect if a motoris not designed to reverse, the bearings or brushes may not be designed to withstand running backwards. You will need air inlets in order to exhaust, anyway. Why not control the inlets instead of reversing the outlet?
The idea of solar vents is to take away heat when the sun is beating down. No batteries means no maintenance. There would be very little market if the vents required homeowners to climb the roof every year (or pay someone to do it) to check or replace the batteries. Their beauty is that they are "set and forget." If you want air exchanges when the sun isn't out, why not find efficient (low current) standard 12-volt power vents to run off of a solar-recharged house battery system? A lot more work and cost, yes, but the system can be up-sized to support other functions like LED lighting, etc.
Old 09-20-2009, 11:17 AM   #4
swinada's Avatar
Re: Solar Vents
hey thanks for your reply Redbear, but this post is over 2 years old. So hopefuly someone new might benefit from your comments. I never bought any so I cant say if they work or not.
Old 09-20-2009, 11:35 AM   #5
Re: Solar Vents
"Old posts never die - they just get new comments."
Old 09-20-2009, 03:44 PM   #6
Re: Solar Vents
I think I saw a solar attic vent fan on Lehman's web site that was reasonably priced.
Has anyone tried insulating a skoolie roof, or is it already low enoung?
Homeskooled is offline   Reply With Quote
leaking ceiling vents jjhomeonewheels Conversion General Discussions 5 02-27-2014 02:10 PM
Solar ovens and solar water heaters/showers tomas_maly Heating, Cooling and Appliances 6 05-22-2013 11:43 AM
Plumbing vents Papabear Conversion General Discussions 3 02-09-2010 05:38 PM
Solar roof vents... or regular? TygerCub Electrical, Charging and Solar 6 08-13-2009 05:44 PM
Roof Vents frank-id Everything Else | General Skoolie Discussions 0 01-14-2008 11:45 AM
