Old 07-11-2018, 03:26 PM   #1
Year: 2005
Engine: Cat C7
Starting Batteries, Where to Get, Forgive Me
Forgive me for not knowing what I don't know. I'm looking at a bus that has bad batteries, they have replaced the alternator but have not replaced the batteries. Where is the best place to get three new batteries if I decide to go look at this bus, and potentially buy it. I live in Michigan, so cold starting is going to be a necessity. Thank you for your help.
tororider is offline   Reply With Quote
Old 07-11-2018, 03:30 PM   #2
Local auto parts store or Walmart.
Old 07-11-2018, 03:40 PM   #3
brokedown's Avatar
If they're regular Group 31 batteries you can get cheap ones from Walmart and they'll probably last 5 years. Or you can pay three times as much and get some that will also last about five years. You didn't mention anything about the bus but most of them have block heaters which make all the difference on the very cold mornings and will really take the edge off of the starting load.
Old 07-11-2018, 03:41 PM   #4
Year: 2005
Engine: Cat C7
Cool, is it universal that buses need group 31 batteries? Is there a different type of terminal size or location to look for?
Check out my life on YouTube...
https://www.youtube.com/c/HomesteadDad
Old 07-11-2018, 03:41 PM   #5
Group 31T, my bus has only one start battery, you may not need 3 to get it started. I have 2 new ones to replace the one. O'Reilly has them for around $120.
Old 07-11-2018, 03:42 PM   #6
Year: 2005
Engine: Cat C7
It's a 2000 Thomas with a 3126 Cat engine.
Old 07-11-2018, 03:46 PM   #7
One Group 31T battery and the new alternator should be enough to start that bus.
Old 07-11-2018, 04:24 PM   #8
brokedown's Avatar
My Vista has a pair of group 31 but my Bluebird has a pair of 8D batteries. Holy crap i don't look forward to replacing those ever. I actually bought all the crap i need to freshen up the battery tray area but you can bet I won't be lifting those bad boys without a friend helping.
Old 07-11-2018, 04:48 PM   #9
I always clean up and repaint the battery tray and compartment when I do the batteries.
Group 31's at Rural King are $79 brand new.
Old 07-11-2018, 04:53 PM   #10
Chassis: IH
I recently bought a pair of Group 31's for my bus at just under $150, out-the-door. They were $69 each +tax.
Shop around. The expensive ones aren't any better than the cheaper ones, in my experience. I got mine at a local mom-and-pop battery shop.
Old 07-11-2018, 08:41 PM   #11
+1 on the "expensive aren't any better". My cheapo Rural King batteries are great.
Old 07-12-2018, 06:50 AM   #12
Year: 2005
Engine: Cat C7
Is this the one?
https://www.ruralking.com/battery-31...31p925cca-post
Old 07-12-2018, 08:26 AM   #13
Originally Posted by tororider View Post
That's a standard post battery, you'll likely need a threaded post making it a 31T and not the 31P. How is your battery connection configured?
Old 07-12-2018, 08:44 AM   #14
Year: 2005
Engine: Cat C7
This is the image I was sent.
D73D8D68-D859-4570-A0FD-F2C13C36B27B.jpg   FA826AEE-32FB-453C-B89D-AAB6E0AC4906.jpg
Old 07-12-2018, 09:23 AM   #15
Year: 2005
Engine: Cat C7
This one? Rural King's website search function is terrible.
https://www.ruralking.com/battery-31x925-ss31-925-stud
Old 07-12-2018, 03:32 PM   #16
YES! Available with threaded or standard posts. Most buses use threaded.
I've used these batteries for years now. They've held up well.
Old 07-12-2018, 03:33 PM   #17
Their site's search IS terrible. The group 31's used to be completely absent and were "in store only".
Old 07-12-2018, 04:20 PM   #18
Those Deka's look like they have a side post terminal on top. I would still use a 31T for those.
Old 07-12-2018, 04:27 PM   #19
They're just regular threaded terminal 31's. Deka makes a good battery but not good enough to cost what they do.
Old 07-12-2018, 08:33 PM   #20
You're saying thats a closed end nut his battery and not a bolt?
