Old 05-01-2017, 04:31 PM   #1
Still having trouble
So I get a diesel mechanic over the spot and of course the bus fires right up I get to a place not on private property and she is not clicking but hardly turning over. Did drop test I the starter and altenator everything looked good .whats really goin on ??
Sunbear is offline   Reply With Quote
Old 05-01-2017, 05:36 PM   #2
Robin97396's Avatar
Did you lock any of the doors or disconnect the hatch? That's my first guess is that you'd be exploring the bus and you've activated the interlock system. Those safety switches have to be in the right position before the interlock system will let your bus start.
Or I could be way off base.
Robin
Nobody's Business
Old 05-01-2017, 06:12 PM   #3
Boost it and let it run for a while and charge. Turn things on so the alternator really has to put out above normal currents and then after turn those things off and see how the alternator reacts.
Seems low battery right now.
Old 05-01-2017, 10:02 PM   #4
roach711's Avatar
Rated Cap: 19
Seems like something's quickly drawing down the battery. Try charging the batt. then check the voltage over the next hours/days. It should start off at 12.7 volts and stay above 12.5v for several days at least. If you see volts dropping down quickly there may be a phantom drain somewhere.
Also, make sure the alt is actually charging the battery. After starting up you should see 14.5 volts or more at the battery posts.
The Roach Motel
Old 05-02-2017, 12:32 PM   #5
Cut off switch
The ground wire to the cutoff switch was hella loose so I tightend it and she started not 100 percent but I think I'm on to something
