Old 03-26-2019, 03:58 PM   #1
Chassis: Blue bird
Engine: Cummins
Rated Cap: it was a bloodmobile
Smile Swap from manual to automatic transfer switch
We have a manual transfer switch for our 17kw generator (it was a blood mobile in its prior life). The transfer switch is old and I want to replace it. I would like to look into replacing it with an automatic transfer switch. The shore power is 50 amp. Any recommendations or advice (besides have an electrician install - which I will have)?
Thanks!
Masoos is offline   Reply With Quote
Old 03-26-2019, 04:10 PM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I have one with surge protection and one without (electrical design here if wondering why two). Both have served me well for two years.
WFCO T57 50 Amp Transfer Switch
Progressive Dynamics PD52DCSV Transfer Switch Surge Protected
JD - Full timer out west
My Adventures & Build
Old 05-05-2019, 04:05 PM   #3
Thank you very much!
Great info. Thanks so much.
RussMarlowe is offline   Reply With Quote
Old 05-06-2019, 10:10 AM   #4
I would install over current protection at the generator sized to protect the wire between the generator and the transfer switch.
Old 06-10-2019, 12:31 PM   #5
JDOnTheGo:
I ended up going with the WFCO that you recommended. It works perfectly! Thank you very much for your help.
Russ
Old 06-10-2019, 03:12 PM   #6
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Excellent!!
electrical, generator, transfer switch
