Old 09-01-2018, 02:38 PM   #1
T444e error help
I am getting coeds 221 and 113 and it won’t turn over. I just trickle charged my batteries and replaced the voltage regulator in my alternator. Any thoughts?
Jsayah is offline   Reply With Quote
Old 09-01-2018, 02:50 PM   #2
Take a look at t444e codes - School Bus Fleet Magazine Forums
Old 09-01-2018, 02:53 PM   #3
Check voltage AT the ECM/TCM.
Look at your ground connections.
Old 09-01-2018, 02:57 PM   #4
I did but it didn’t help me.
Old 09-01-2018, 02:57 PM   #5
Any chance you could link some material. I’m a newbie to this.
Old 09-01-2018, 03:14 PM   #6
I am not familiar enough with the T444e ECM connections to tell you specifically where to look.
Hopefully one of the many T444e owners here will chime in.
Old 09-01-2018, 04:48 PM   #7
the telltale code is the 113.. thats one telling you that the always-hot Battery positive is low or zero volts.. it helps to know what year and what type of bus it is.. (FE, RE, 3800 conventional?
if its a conventional 3800 series bus.. then check your ECM fuses in the fuse panel on the front dash.. .. this could just be a stored code.. but the ECM will store codes and not operate the power relay (needed to start). if it has good Ignition key voltage but no-good battery plus voltage..
I have wiring diagrams for some of the busses..
Old 09-01-2018, 05:30 PM   #8
It’s an 95 international 3800, blue bird chassis. It has the 7.3l t444e @216k miles. The cables to my battery’s are a bit corroded. I will check the fuse panel as well like you suggested. A diagram would be helpful as I’m fairly new to this. It’s my first Skoolie, The Skallywagon. I got it for 1500 dollars and It was driving for a while. I drove it from Sanford to windham out here in Maine and around town with no issues but then I left for a couple weeks and I came back to this. I’ll post some pictures soon. It definitely needs rust work in the back I’m about to treat it with ospho and patch it up with some new steel.
