Old 08-23-2010, 08:10 PM   #1
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Thinking of this generator. Opinions?
I was looking at one of these. I know its a cheapy. I really only need about 5500 watts. But this has the 50 amp range plug on it that I can really use. Is it a true 8000 watts continuous? Maybe not. But I don't need that much anyway.
I don't believe the lower wattage ones have the capability for 50 amp service.
It also has a electric start. I was thinking if I mount this under the bus. Maybe I can run the ignition and wires all the way to the dash so I can start it in the bus.
Any thoughts?
Dan
BUSBOZO is offline   Reply With Quote
Old 08-23-2010, 08:46 PM   #2
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Re: Thinking of this generator. Opinions?
Whoops. Forgot the link.
.http://cgi.ebay.com/NEW-QUIET-PORTABLE- ... ltDomain_0
Old 08-24-2010, 10:07 AM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
If you're planning to spend that kind of money and get a generator of that size, you might consider getting a diesel. I've heard there are 5500W chinese-made diesel generators for $800-$900.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 08-24-2010, 06:16 PM   #4
I havent seen or used a generator like that, but I have checked them out on ebay, I must say , for the price it should be a good , I wouldnt be scared to buy one, but here in canada the frt would be to much. Im looking a 7000 electric start generac. How would you mount it? its big in size and weight., also ot run the starter switch, you may have to run something to operate the choke as well, most electric starts iv seen you have to pull the choke out by hand.
Im thinking out mounting my genny on a rear deck, may 2.5 ft wide.
all in all I dont think you can go wrong with that one, unless you win the lotto and can buy a honda!!
just my two cents
Old 08-24-2010, 07:30 PM   #5
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
DD, that would be awesome to get a diesel. Then I could tie it in to my fuel tank.
gbstewart, I was wondering about the choke. MMM.. That generator you are looking at probably weighs around 300 pounds. I will weld together something sturdy and mount it to the frame under the bus. I just need to figure out how I want to make it accessible. A slide mount would be nice. But I don't even know where to start with something like that.
Old 08-24-2010, 07:42 PM   #6
I know what you mean about building a slide out for the genny, thats why I thinking about building a small deck at the back, this will give me a place to other stuff, like fire wood , gas cans, etc, it will make it more accessable, and can take it off during the winter, Im going to think about more and see what happens, will post
let us know what you get for a genny, Im not a fan of cutting into a spliceing into the fuel line, so im sticking with gas for a generator but thats just me.
Old 08-24-2010, 09:38 PM   #7
Realize that having a 50-amp, 240-volt OUTLET does not mean that it puts out that much power, only that your plug will fit. 50 Amps x 240 volts = 12,000 watts. In order to get the FULL 50 amps, you would need a generator with 12 kW continuous, probably 15 kW peak.
Now, most of us don't need anywhere near that much power, 8 kW might be plenty enough to power 2 or 3 of our buses, I'm just sayin'.
I would not be afraid to buy that generator at that price. For reference, I pay many thousands for a commercial 8500 watt liquid-cooled gas standby generator with a propane carb, outdoor cabinet, transfer panel, battery charger, and NO installation.
My main concern is considering the cooling air when you plan your mount. Getting it too hot will shorten its life. I noticed a low oil shutdown but not an over-temp one, unless I missed it. If you planned to drop it on the ground and run it next to the bus, instead of hiding it in a compartment, you would probably have a greater danger of it "growing legs" than failing.
In order to make 60 Hertz (cycles per second to us old-timers), non-inverter generators need to run at either 1800 or 3600 rpm, depending on the windings. A rule of thumb is to expect a gas 3600 rpm genny to last about 1000 hours without a rebuild. A diesel is more likely to run at 1800 tpm, multiplying the reliability.
If you get 1000 hours out of it and throw it away, figure it had cost you 90 per hour to run. The three quarts of gas per hour burned at 8 kW continuous output will cost you more.
Old 08-25-2010, 10:55 AM   #8
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by Iceni John
... If you have space for it, and if you can make a hefty slide-mount for it (you'll need something much beefier than the Accuride 4034 slides I used for mine)...
You should have used Accuride 9301's for your slides. 4034's are only rated for a 150LB load.
http://www.rockler.com/product.cfm?page=1491
This page will show you what the load ratings for Accuride slides. The loads are generally figured for a 24" wide drawer NOT WIDER (check the tech sheets to make sure about your loads for the width you want).
http://www.rockler.com/articles/accu...ison-guide.cfm
Fulltime since 2006
Old 08-25-2010, 09:51 PM   #9
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Thanks for the info guys!
Old 08-26-2010, 05:02 PM   #10
Coachwork: Ward Genesis
Engine: DT466/MT643
The configuration and being air-cooled (and probably 3600RPM) make me think this one will be raucous. If you boondock alone, fine...probably not welcome in a campground. I'd bet it's a Chinese-made genset and part/repair support will be nil within a year.
Although, 1000 hours for even a cheap genset is pretty low!
Personally, I'm going diesel (once I find one)...for gas, I'd haunt eBay & the like for a Honda EU series. Reliable, silent, and bulletproof.
Jarlaxle
Thinking of buying this bus. What do you think? hello_im_alex Classifieds | Buy, Sell, Swap 16 12-19-2011 05:48 PM
Generator help/ opinions of this model bapos Conversion General Discussions 11 07-17-2011 08:30 PM
Thinking about buying this... GreyEagle Classifieds | Buy, Sell, Swap 0 05-08-2011 10:28 AM
Thinking of getting another bus hoser Everything Else | General Skoolie Discussions 0 01-16-2010 02:44 PM
Put your thinking caps on. crazycal Everything Else | General Skoolie Discussions 9 11-26-2007 03:22 PM
