Old 05-27-2019, 12:13 PM   #1
Toggle switch under dash, unknown purpose
Hello all. Hoping you can help me out. I have a 2007 International CE300. During my initial clean up I found a toggle switch under the dash board, towards right side behind front heater.
It isnít mounted to anything, just hanging, but it certainly appears to be part of the factory harness.
I havenít touched it for fear it might be a self destruct switch.
Thanks in advance!
Uneducated is offline   Reply With Quote
Old 05-27-2019, 12:31 PM   #2
TheHubbardBus's Avatar
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
That's either the caltrops dispenser, or the rear mounted .50 machine gun.
(sorry, no clue)
Old 05-27-2019, 01:10 PM   #3
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
Thanks in advance!
That's right by the fuse panel on the outside, i bet you can trace it back and identify it easily by having someone stand inside and tug the wire while you look in the panel
CMORGANSKOOL is offline   Reply With Quote
Old 05-27-2019, 01:23 PM   #4
Poggalicious's Avatar
Chassis: International Amtran
Engine: Navistar 7.3L
I was going to guess, itís for the NO2.
Poggalicious is offline   Reply With Quote
