Old 02-04-2019, 06:59 PM   #1
turn signals work hazard lights do not 97 Ford/Thomas
after disconnecting all the extra lights i have everything working except the hazard lights, the turn signals all work fine. Any suggestions would be greatly appreciated.
jprice692004 is offline   Reply With Quote
Old 02-07-2019, 10:51 AM   #2
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I have the same situation so curious for response. I would like my hazards to work...
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 02-07-2019, 11:45 AM   #3
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
Make sure contacts are properly seated on hazard toggle connectors.
Ensure that if you have an external light monitor, that all contacts are properly seated.
Check this thread.
geminusprime is offline   Reply With Quote
Old 02-07-2019, 04:09 PM   #4
got them working again
I found the original fuse box, the labels were unreadable, so I just started checking fuses found one 20 amp blown, replaced with a 15 amp, and they started working. Sometimes its the simplest things.
Old 02-07-2019, 06:16 PM   #5
Gotta love a simple (and cheap) fix!
Old 02-07-2019, 07:06 PM   #6
So changing a fuse got you power back but have you found out why it blew in the first place? I don't hink you are done yet.
How long have you owned the bus? And you never bothered to find out where fuse box was? That is the absolute first thing one should find and get familiar with.
flashers, hazard lights, turn signals
