Old 08-04-2012, 03:55 PM   #11
Re: using the engine as a generator
Yeah, I think that getting your inverter situation figured out is your best bet. As others have mentioned, getting a stable RPM at 60 hz isn't something that your engine is currently designed to do, and a modification would be a pain in the ass, and you'd probably end up adding extra drag to your engine that would eat up HP when driving around. I know others do, but I'm also not a fan of tapping into the air brakes. Messing with your braking system just seems scary to me.
Going the inverter route, any electric motor takes a little extra juice to get started, so you probably just need a bigger inverter. As a general rule, if you aim for twice the pump's power draw, you should be ok. I'm not sure where the $3000 price tag chev49 mentioned is coming from, that seems way high. I have a 6000 watt Powerbright inverter for around $600 which is way overkill for pretty much anything. (side story: It is not, apparently, overkill for cooking a hot dog with direct AC current through jumper cables, and I am currently awaiting a new inverter from Powerbright covered under my warranty ) You probably need about a 3000 watt inverter, which you can probably find on ebay for ~$100. Depending on how long you need to run your pump to fill your tank, you may or may not need A) a bigger/second alternator, or B) a bigger battery bank. I'd start with a new alternator, and keep an eye on the voltage drop as you fill.
icnivad is offline   Reply With Quote
Old 08-05-2012, 06:40 PM   #12
lapeer20m's Avatar
Originally Posted by bus-bro
If you're using a jet pump that would mean you are trying to lift water at 20 plus foot elevation. If you put a portable pump closer to the source of water you could use a pump that would draw less current than a jet pump. Then you'd need to size the power cord to the pump. It then becomes more of a question of how much water you want to lift in a given time, and, of course, the total lift.
THIS!
to move water, it is very very difficult to suck or pull water over a long distance or elevation. As a matter of fact, it is impossible to pull water much over 25 feet elevation.
It is much easier and more efficient to pump or push water. Get a pump you can put near the water source and pump it to the bus. Either 12 volt, 110 volt or an actual gasoline powered pump.
If you want to use your bus engine to pump water, you need attach a pump to the bus engine (think firetruck) But this pump needs to only turn when you want to move water. It cannot spin when there is no water or you will burn it up. But for this to work, you need to park near the water source. Many pumps are not rated for any sort of side loading, so you cannot simply run it off a belt, but requires a drive shaft or similar setup.
The simplest solution is either a larger inverter to run your existing pump, or a smaller pump. 110 volts through your inverter has the advantage that if you are going to run the pump any distance away from the bus you can use an extension cord. You need to carry 10 times the current to run a similar size pump at 12 volts which makes it not practical at any distance because of the size conductors required.
depending on how many gallons per minute you require a small 12 volt pump and a spare bus battery near the water source may be a good solution.
as far as engine powered generator, there are commercial engine driven generators that are hydraulic drive. Your engine turns a hydraulic pump that spins a hydraulic motor that spins a generator head. I imagine these start at about $10K These allow for varying engine speed while keeping volts and hz relatively constant.
One thing i've thought would be fun to play with is a honda inverter type generator coupled to a bus engine. Most generators require constant rpm to make the proper output 110 volts and 60 hz. The honda eu series are different as they make 110 volts and 60 hz at various speeds. (they are actually a complex alternator and an inverter) If only you could find a cheap honda with a damaged motor you could modify to spin off the bus engine with a belt. Then you could make pure 60 hz power at any speed.
Possible to replace engine with larger engine? Alexlorraine01 Conversion General Discussions 4 04-22-2014 06:22 PM
Dog Nose vs. front engine vs. rear engine? dgorila1 Conversion General Discussions 20 12-21-2011 07:40 PM
Rear engine VS Front engine (TC Style) BBTC2K Conversion General Discussions 2 12-02-2009 11:25 PM
110v engine generator Kirbystud Conversion General Discussions 7 05-29-2005 09:59 PM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 09:15 PM
