Old 12-22-2018, 02:08 AM   #21
Originally Posted by ComfortEagle View Post
I'll bet that's not the only "closet filled with light bulbs" at your house...
Our laws are soon to allow this.
Old 12-22-2018, 11:01 AM   #22
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
It's about time. We should be able to use whatever bulbs we want and not have to hide them in closets.
Old 12-22-2018, 01:32 PM   #23
ComfortEagle's Avatar
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Rated Cap: 87, says Gillig...
You made me laugh that time. I ran across this video; you may have already seen it. It makes a good case for those VDO LEDs...
ComfortEagle is offline   Reply With Quote
Old 12-22-2018, 10:09 PM   #24
TJones's Avatar
Chassis: CS RE
Yup I saw that one. I've got one red and blue on the way. I'm looking for a seller that doesn't charge as much for the shipping as they do for the HD White. I could have a very patriotic theme but it would not be easy on the eyes.
Ted
Old 12-23-2018, 05:45 AM   #25
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Ted
I am a doofus... I just noticed that you referenced that youtube video several post before I chimed in with it. I should pay attention...
Old 12-23-2018, 08:43 AM   #26
TJones's Avatar
Chassis: CS RE
That's ok. I'm not smart enough to embed the player in the post.
Old 12-23-2018, 08:51 AM   #27
Just copy the url and paste it directly without using the tool bar.
Old 12-23-2018, 09:43 AM   #28
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Great, now Ted is smart, but I am still a doofus ...
Old 12-23-2018, 09:51 AM   #29
Well ain't that just bama lama lam!
Old 12-24-2018, 04:31 AM   #30
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Bama Lama Lam?
Old 12-26-2018, 11:23 PM   #31
Has anyone got any idea what happens when an led light is aimed through a prism? I have neither but wonder if it might diffuse the led and help with a wider illumination area.
If so maybe a deflector could be made over the switch panel for a unique affect.
IIRC LEDs are monochromatic, only emitting one wavelength of light. So a prism would just bend the whole output through some angle and send it some direction. Useful? You be the judge.
a 70's era Cessna 172 single engine 4-seater aircraft I once owned a share in had a nice panel illumination setup. The whole of the panel had a piece of ~1/8" plexi behind the faux wood grain, with holes drilled through both. The plexi was essentially the size of the panel itself. Grain-of-wheat lamps were placed around each instrument in holes or indents in the plexi; I forget which. The plexi served to diffuse the light evenly around the whole of each instrument cutout, and provide a sort of "redundancy" if one bulb went out. Worked pretty well, with no bright/dim spots on the instrument faces.
Old 12-27-2018, 03:30 AM   #32
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Originally Posted by dan-fox View Post
IIRC LEDs are monochromatic, only emitting one wavelength of light. So a prism...
If you guys really want to learn about light refraction and prisms, I recommend this product from Irwin Mainway.
...a 70's era Cessna 172 single engine 4-seater aircraft I once owned a share in...
Nice touch...
Old 12-27-2018, 07:47 AM   #33
"IIRC LEDs are monochromatic, only emitting one wavelength of light. So a prism would just bend the whole output through some angle and send it some direction. Useful? You be the judge. " Dan Fox
Thanks Dan, was hoping that a prism might be a deflector or diffuser to redirect that beam. Sounds doable.
Old 02-01-2019, 10:11 PM   #34
TJones's Avatar
Chassis: CS RE
Vdo led comparison
The USPS finally found and delivered my HD White LED that I ordered back around Christmas time. So here is the comparison between VDOs red, white and blue led upgrades. I'm leaning toward either the red or the white. The blue is too difficult to see. The white does make the gauge really crisp and easy to read. The red may be easier on the eyes. I still need to take all the incandescent bulbs out and spread the LEDs out so they are not next to each other and put the head lights on before I pass final judgement. The blue will be nice illumination for the bluebird on my dash.
Ted
Old 02-02-2019, 03:29 AM   #35
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Ted
FWIW, I agree. Again, if your gauges are not currently dimmable, adding a dimmer (like this one), although not free, could be the perfect finishing touch, especially if you go with the white LEDs. The white does look really nice in your pic, but I wonder if a dashboard full of them may be as bright as ECCB's grow lights.
Old 02-02-2019, 08:25 AM   #36
TJones's Avatar
Chassis: CS RE
My factory dimmer seems to work with the bulbs. The red is not as bright as your gauges. The reds at their brightest seem to be about the same as the HD white at the dimmest. The neat thing with the HD white is it stays white as you dim it. There is no yellowing like the incandescents. The white light seems to absorb into the black gauge face much more than the yellow.
Ted
Old 02-02-2019, 08:38 AM   #37
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Funny, my crappy Gillig dash didn't even have a factory dimmer...
Old 02-02-2019, 12:12 PM   #38
Ted
Another vote for the white LEDs with the dimmer.
Would it be possible to install two dimmers, so that your core gauges could remain at full brightness, while the others are dimmed a little bit to keep the ambient light down while driving?
The gauge needle disappears too much on the red IMO, defeating the purpose of the gauge in the first place.
Old 02-02-2019, 12:20 PM   #39
Gillig doesn't like dim bulbs behind the wheels of their fine coaches.
Old 02-02-2019, 05:21 PM   #40
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I went with green LEDs. Currently waiting on a new headlight switch unit to reassemble the dash board. Green is, from what I read somewhere, the color that is least disturbing to your night vision. I could be wrong though
Nick
