Old 08-16-2018, 11:23 AM   #1
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Warning buzzer?
89 international S1800 9.L when i connect the battery a buzzer sounds. But once the bus is running it stops. No air brakes. No compressor. It sounds like its in the middle of the fire wall..any suggestion will be greatly appreciated.
mikeypj is offline   Reply With Quote
Old 08-16-2018, 02:47 PM   #2
When you shut the engine down does it stop right away? Is this a one time issue? Thinking it might be related to oil pressure but might be wired incorrectly at this moment. Are the doors shut or open when you are out there playing?
Old 08-16-2018, 06:20 PM   #3
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
The guy i bought it from said it "just started doing.".right now its just a pain to start..he said door buzzer was off and yes it does it after you shut it down too
Old 08-16-2018, 07:45 PM   #4
Well find the buzzer and get it silenced.
Old 08-16-2018, 07:49 PM   #5
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Thats the plan..theres a lot of smart people on here and I'm tapping into the wealth of knowledge.
Old 08-16-2018, 07:58 PM   #6
Sure but it's you there to do this, not us.
Gotta start getting to know your buses workings.
Old 08-16-2018, 09:05 PM   #7
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
So asking for info, help or whatever is frowned upon? Im building a bus, im learning as i go. I ask so i can learn. I was under the assumption this was a group to help others with their buses and builds.
Old 08-17-2018, 05:19 AM   #8
Nobody said that at all. My God, it's only a buzzer and I gave you some suggestions. if I was there I would dig into it like amyone else and figure it out.Maybe read up on electricity if owning a bus. You might have a serious problem if that buzzer is sounding so it is up to YOU. getyour hands in there and trace it out.
Old 08-17-2018, 06:10 AM   #9
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Lol..yeah, i know im the only one to fix it..im quite capable..i asked only for info..i assure you im not one of those that are interested until it gets hard. Get used to my questions, even dumb ones.. thanks for your input. Its really appreciated. Have a fantastic day!
Old 08-19-2018, 07:33 PM   #10
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
The "buzzer" is the e-brake switch and its causing the 12v assist to cycle..which creates a buzzing sound. Didnt know the bus had the assist..
