Old 02-15-2018, 08:00 PM   #1
RayAllen's Avatar
Coachwork: Goshen Freightliner
Water heater
Guys I have the Suburban SW6DE model which is Propane and 120v. My question instead of wiring/hard wiring directly to the electrical panel 20amp breaker can I not just run romex from the panel to a designated 20a outlet solely for the water heater. Id like to also add a 110wall switch with light to turn on and off when ever wed like. Whats strange is the SW6de model 12v side has its own ground wire but the 120v side only has the hot and neutral..
What do you guys think?
RayAllen is offline   Reply With Quote
Old 02-15-2018, 08:19 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Don't know as far as your equipment terminations?
I always recommend stranded wire verses solid wire.
I use old extension cords salvaged from my job that are 12-guage and are already protected and or very easy to push/pull through a conduit?
Just my thoughts?
Old 02-15-2018, 08:27 PM   #3
Year: 86
Chassis: Ford B700
Engine: 8.2
Sorry read your post but didn't read it.
There are better sparkies here than I?
For the 120 you need to run a ground and there should be a designated ground screw inside the electrical box for you to connect it to.
Usually a dark green one hidden in a mucked up spot.
If you use an extension cord for the 12v and only need two wires then you always have a spare wire there if you have a wire go bad somewhere?
Good luck
Old 02-15-2018, 09:27 PM   #4
Assuming you will put a male plug on the heater cord itself, yes you can end the run from the panel to the receptacle so you can unplug and remove the heater. Thats how I'm planning my build, very little in hard wired appliances so upgrades or replacement is straight forward.
o1marc is online now   Reply With Quote
Old 02-16-2018, 01:51 AM   #5
RayAllen's Avatar
Exactly what I was planning to do. It would be nice to be able to simply unplug it versus having to turn the breaker off and open a junction box to get to wiring.
Old 02-18-2018, 06:43 PM   #6
Ray,
I'm putting this heater in my current build. You can definitely run it off a dedicated 20A, 120v AC outlet. It's the same as hard-wiring it to your AC breaker box, just with a longer set of wire. You could use Suburban's water heater switch, which can toggle the gas and electric independently.
I'm also adding a timer so that you can specify your water heater to run from 7am-8am for a 7:45am shower, for example. This way you don't have to get up early, flip the switch, and wait for the water to heat up.
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
Old 02-18-2018, 06:49 PM   #7
RayAllen's Avatar
Originally Posted by ThunderstruckStudios View Post
Ray,
Great Idea on the timer. I will be wiring it up this week. Picked up the 20amp breaker, outlet and switch yesterday.
1999 30 Freightliner MB Series shuttle/coach bus. 24v Cummins/Allison with Air Suspension.
Old 02-18-2018, 06:50 PM   #8
Good stuff. Will be interested to see what you come up with if you do a follow-up post.
