Old 01-15-2017, 04:20 PM   #1
Coachwork: blue bird
Engine: international 3800 t444e 7.3L
what size diode for solar panels?
im near to having my basic solar setup complete. im told that i need a diode on the positive wire in between the panel and charge controller. i have two panels that i plan to hook together, so i guess i need a diode for each one?
well i walked into radio shack and asked the guy to help me find diodes but he knew nothing about solar or which size diodes i needed. he did show me to the drawers of diodes for me to pick from tho.
so i guess im trying to figure out what size diodes i need? i plan on getting my one 190watt panel working and then adding my other 190 watt panel.
thank you all for your help
welcomehome is offline   Reply With Quote
Old 01-15-2017, 07:16 PM   #2
Chassis: B3800 Short bus
Most panels have diodes built in.. I haven't seen any that are designed otherwise. If this holds true then you don't need any additional diodes. Unless you were wiring them in series, I suppose, and wanted a bypass diode..
Old 01-15-2017, 07:56 PM   #3
warewolff's Avatar
Your charger should have a diode as well.
warewolff is offline   Reply With Quote
