Originally Posted by o1marc
And what would your concern for widening one be?
The "L" shapes all over the lift components make the structural rigidity of the lift. They keep it from racking sideways when you're lifting a wheelchair with the bus on a hill or lowering the lift onto uneven ground. The two lift cylinders are plumbed into a tee fitting before the pump so there's a reliance on the rigidity to synchronize them.
As soon as you widen the lift, which requires stretching the base plate and the platform, the twisting forces are exponentially greater through the leverage of the mechanisms...
I'm sure it can/has been done. But knowing what I know and doing what I've done with these lifts, I can't see widening being that good of an idea.
Better off getting a used Tommy Gate at that point...
Sent from my E6883 using Tapatalk
