Old 02-04-2018, 08:23 PM   #1
When to install solar panels? newbie here?
So from a step by step point of view, would you get solar before a ceiling (ceiling will be wood, probably tongue and grove), or does that not matter?
kline400 is offline   Reply With Quote
Old 02-06-2018, 12:48 PM   #2
I'd think that you should plan it out pretty early in the process since you're going to want access to the interior of the roof for mounting hardware, wiring ingress, etc.
Old 02-06-2018, 01:51 PM   #3
If you're planning T&G, you'll want your solar panel rack installed before sealing up the inside ceiling and all of your wiring run in your roof.
ben2go is offline   Reply With Quote
Old 02-09-2018, 11:56 AM   #4
thanks man I appreciate that
Old 02-18-2018, 06:39 PM   #5
I agree with Dan and Ben. I'd plan out all of the electrical wiring before putting in any insulation or building walls/ceiling.
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
installation, solar panels, steps
