Old 05-27-2017, 12:32 PM   #1
Where do you get giant starter batteries
I have an E-450 based cutaway shuttle bus. I was having trouble getting it to start and finally solved the problem. My other starter battery has a bad cell. Unfortunately this thing is HUGE. The size of 3 or 4 normal vehicle batteries.
specs: C8D3, CCA 1300, CA 1560, RC 435
How does one go about replacing such a thing. Will they just order one for me at advanced auto? Sorry if this is kind of a silly question.
Thanks in advance!
TheStinker is offline   Reply With Quote
Old 05-27-2017, 01:02 PM   #2
Chassis: IH
Thanks in advance!
If it were me, I would consider the possibility of replacing it with a pair of "Group 31" batteries (the common truck-style batteries typically grouped together). These Group 8 batteries like you have are adequate, but very heavy and awkward to manhandle, and as you found out, one dead cell will leave you stranded.
Not many places will have a Group 8 battery. The group 31's are fairly common. Not sure if Advance will have these (or Wal-Mart, for that matter). I generally use a local mom-and-pop battery shop, he keeps dozens of odd sizes in stock and usually beats chain-store prices.
If you go this route, you'll probably need to change the battery cable ends, and get the short cables to wire the second battery to the first.
Old 05-27-2017, 01:02 PM   #3
Robin97396's Avatar
You have an 8D battery. They're very heavy, so most of us prefer using two 31s or some such setup.
Go to your local farm supply store to get a good deal on batteries.
Robin
Nobody's Business
Old 05-27-2017, 01:15 PM   #4
Thanks. That sounds like a good plan, but can somebody direct to some information to figure out what to get and how to wire it? Parallel? series? Is there such thing as too much power? I know there's such a thing as too little. I'm not very good with this electrical stuff, just need my bus to start every time.
thanks
Old 05-27-2017, 01:25 PM   #5
Chassis: IH
thanks
Wire the 31's in parallel. Do *NOT* wire them in series (you'll get 24 volts to your system than way, likely destroying fuses and sensitive electronics!).
Red-to-red, black-to-black.
Given that you're running a Ford van, presumably with a 7.3 diesel, two group 31 batteries should be fine for starting. One strong battery would probably do it for a few weeks.
Old 05-27-2017, 01:29 PM   #6
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
To keep 12v, wire all the positives together and all the negatives. See illustration below.
Old 05-27-2017, 01:55 PM   #7
Thank you so much!
So here's what it originally had: 850cca battery and a 1300cca battery totaling 2150 cca
I now have two 850cca batteries in good shape totaling 1700 cca.
Is there a reason not to just get a battery with 450 cca to round it out? That would make for a three battery starter system. Is that rational?
Old 05-27-2017, 02:08 PM   #8
Robin97396's Avatar
No, it's not really rational to have a three battery starting system. It's overkill. Two batteries is great. It starts well now, doesn't it?
Robin
Nobody's Business
Old 05-27-2017, 02:09 PM   #9
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
If you have the room and the funds, more is better.
When I bought my bus it had 2 dead 8d (the big ones). I know I won't need them, they will run the starter and body/head lights. There won't be the 8 ways or the strobe. I won't be driving a bus route with lots of idle time. But I got a good deal on 2 8d Batts, so I put 2 in. A Cummins 5.9 would have been just fine with 2 group 31 batteries.
Old 05-27-2017, 02:39 PM   #10
Chassis: IH
Nah, I wouldn't mix-and-match batteries like this. Some big trucks use 3 batteries and many road tractors use 4. The reason isn't so much because they need 4000 CCA, but because as the batteries age, they don't provide as much power. I had a Volvo last year with a Cummins ISX engine that wouldn't start during a cold snap. When I went to the battery shop, it was determined 2 (of the 4) were completely dead, 1 was weak, 1 was fair. So we established that I had been starting on 2 batteries for some time. Also, the dead batteries "felt light" compared to the others, they were "dry", so to speak.
Old 05-28-2017, 12:30 PM   #11
so maybe i should just use the two 850cca batteries I have and not worry about it? It's seems like a relatively small power loss (450cca) considering I don't need to run the wheel chair lift anymore.
Old 05-28-2017, 12:59 PM   #12
Chassis: IH
That's what I feel. I can't see that 7.3 needing more than 700-800 amps to start. If you ran 1600 amps through the battery cables you likely have, they'd probably melt fairly quickly anyway.
I had one battery going in my IH 9L (and the hot post wasn't even tight, it was merely making light contact) and I was able to start it up. Then again, the 9L doesn't have much of an electrical system either, no glow plugs or preheater.
Old 05-28-2017, 02:08 PM   #13
my T-444E (7.3) seems to need very little power to start... even in 0 degree temperatures, i used one glow plug cycle and it started up just like a warm day .. it didnt hardly swing at all.. (and thats with 15W40 rotella regular oil). my ammeter charged heavy for less than a minute before backing way off showing mew that I didnt use a lot of battery power.. I have 2 group 31 Batteries dated like 2013 or something so they are old and still work fine.
