Old 03-25-2019, 05:36 PM   #1
Engine: Cat C7
Wiring a 12 volt socket
I thought this task was straightforward. I want to connect a 12 volt outlet to my bus. I put the terminal in an empty fuse slot and grounded it. See photo. No juice. I know that the fuse has power because I tested it with a voltmeter and it read 12 volts.
What am I doing wrong?
File Type: jpg 23C85EB0-C37E-486B-8A38-014E7A0ADC94.jpg (237.8 KB, 34 views)
TeacherJoe is offline   Reply With Quote
Old 03-25-2019, 05:38 PM   #2
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
Double check the ground?
Dave
Old 03-25-2019, 06:42 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
All of those type fuse taps I can find need a fuse plugged into it. Is there a place on the side that looks like a fuse would plug into it? By the way those look like circuit breakers on your bus not fuses. A couple of them look a mite crispy but, could just be the picture.
Old 03-25-2019, 09:17 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
The red wire on the right?
So when you meter the socket you get power but not when you meter the wire?
As others said, either a missing in-line fuse or a bad ground.
Is that butt splice solid? I have pretty well sworn those off...solder is slower, but it doesnít fail.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 03-26-2019, 04:33 AM   #5
Engine: Cat C7
Yes, regarding the metering. It has a good inline fuse. I think youíre probably right about the butt splice. Iíll redo that. Thanks.
Joe
12 volt, fuse, ground, socket
