Originally Posted by david.dgeorge07
The red wire on the right?
So when you meter the socket you get power but not when you meter the wire?
As others said, either a missing in-line fuse or a bad ground.
Is that butt splice solid? I have pretty well sworn those off...solder is slower, but it doesn’t fail.
Yes, regarding the metering. It has a good inline fuse. I think you’re probably right about the butt splice. I’ll redo that. Thanks.
Joe
