Old 01-27-2019, 10:23 AM   #1
DogHouse's Avatar
Wiring Diagram Know how Fuse Box
Does anyone have a 2002 Corbeil Chevy 3500 6.5 Diesel Wiring Diagram for the Fuse Box/ Control Panel Above the Driver seat that runs the shuttle part of the bus? Have issues disconnecting the solenoid and keeping the tail lights running,
DogHouse is offline   Reply With Quote
Old 01-27-2019, 12:56 PM   #2
Why are you disconnecting that solenoid anyway?
Tailights come on with the headlight switch normally but fused separately from headlights. I assume that solenoid is fed directly from the batteries. You should have a lot more than no tailights happening if you are disconnecting it.
I would do some testing of the headlight switch for power. Normally 2 circuits at the switch both hot and pulling the switch out turns the lights on.
No diagram so good luck.
Old 01-27-2019, 03:42 PM   #3
DogHouse's Avatar
Thanks here's a pic of what I am working with. The solenoid pos/neg has been disconnected. Any ideas.
Old 01-27-2019, 03:47 PM   #4
DogHouse's Avatar
Here's is the pic
Old 01-27-2019, 06:53 PM   #5
Thanks for the pic, meant to ask but forgot.
What I see is that fuse block directly below the solenoid. No power to it. Should be fed from the solenoid I would think.
There is another wire behind the black one. That too should be on the solenoid.
The blue and white, no clue, you'll need to trace both.
Old 01-27-2019, 09:38 PM   #6
DogHouse's Avatar
Thanks for that... I am trying to remove that fuse box/ control panel by disconnecting the solenoid to re-route the auxiliary switches like the fan, rear dome lights, etc that are on that panel to the Chevy van fuse box. Basically by-pass it. Any suggestions? Can that fuse box/panel be by-passed?
Old 01-29-2019, 12:39 PM   #7
weboughtabus's Avatar
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
I got some wiring diagrams from Collins. They're saved to my Dropbox. Link in this thread I started.
charlotte_thebus on Instagram
weboughtabus is offline   Reply With Quote
chevy diesel, corbeil, wiring
