Old 03-19-2010, 01:58 PM   #1
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Xantrex problem (or dumb operator error)
Just won a Xantrex Freedom 458 inverter/charger model 22 with optional 15 and 20 amp breakers.
on Ebay.
Guy said he tested the functions and everything works.
I receive it, unit powers up, green invert light is steady indicating invert mode.
Breakers are on, but NO AC OUTPUT. I have a 12 volt battery jump pack powering it.
All it's doing is a minor clicking. I would think I would hear the transformer buzzing and the cooling fan.
Any ideas from people who own these?
BUSBOZO is offline   Reply With Quote
Old 03-19-2010, 02:16 PM   #2
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: Xantrex problem (or dumb operator error)
I don't own one, but try it with a 12 volt battery.
In fact, page 11 of the owner's manual states "Do not use car starting batteries."
Owner's manual here:
http://www.xantrex.com/web/id/49/p/docs ... roduct.asp
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 03-19-2010, 08:23 PM   #3
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
I did see that in the manual. I think they say not too use starting batteries because they are not designed for deep discharges. I would think just to test it out, I could use a regular battery.
Old 03-20-2010, 05:40 PM   #4
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Are the breakers in the ON position?
Is the unit going into an error code? My Xantrex doesnt like low voltage, and a jump box probably wont feed a big inverter for long, if at all.
Probably best to attempt a more correct testing set-up, and read the manual one more time.
Ob1 is offline   Reply With Quote
Old 03-20-2010, 07:08 PM   #5
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
Yes, breakers are in "on" position. No error codes. The jump box I was using is quite large and used for jump starting buses at work. Maybe I'll try an 8D battery and see if that will fire it up.
I have not bought my battery bank yet.
Old 03-22-2010, 09:05 PM   #6
Did you put a load on the output, or are you just looking for AC volts with a high-impedance digital meter? A lot of inverters go into "standby" when they are enabled and there is no current draw. A meter is not enough to start it. The clicking may be the unit searching for a load?
For example, we had the power go out during a big game a couple of years ago, so I dragged in a 100 AH gel cell and my (non-Xantrex) inverter and plugged in the TV. The inverter would not start because the TV had shut off. I plugged in a 60-watt lamp, the inverter started, I turned on the TV, turned off the lamp, and we watched the rest of the game.
If you have a battery that measures 12-13 volts DC without dropping, and a 100-watt load on the AC side, and it still doesn't start, then I would worry.
Old 03-24-2010, 06:58 PM   #7
Coachwork: THOMAS
Engine: CAT 3116
Rated Cap: 83
BINGO REDBEAR!!!! Its funny, I was just going to post the outcome of the situation when I read your reply. Funny story... I was actually at the UPS counter ready to ship it back when I decided to hold off and see if the seller would split the cost of shipping it back. He said he would. So I figured I'd ship it out after work today.
Then this morning I ran into a another guy selling the same inverter on ebay. And in his description he stated he put a load on the AC output to test it. I thought to myself.. hmmmm I didn't try that yet. So just for the hell of it I emailed him and asked him a few questions and told him the symptoms and he said the same thing you did.
So I figured, what do I have to lose? Might as well try it. TAHH DAHHH!!! WORKS!!!
And would you believe that I spoke to a authorized xantrex service center and he said it sounds like the control and relay board! And it would cost around $400!
BOY AM I GLAD IT WORKS! I ONLY PAID $416.00 FOR IT!!
Xantrex LinkLITE and LinkPRO battery monitors - NIB southforsunshine Classifieds | Buy, Sell, Swap 0 11-10-2013 11:40 PM
Xantrex Freedom 458 Invertor/charger SOLD jvhooser Classifieds | Buy, Sell, Swap 2 05-22-2012 11:29 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
WHAT is this guys problem lornaschinske Everything Else | General Skoolie Discussions 24 06-03-2010 07:45 AM
dumb question window removal Desertdueler Conversion General Discussions 6 01-28-2007 08:00 PM
