Old 06-17-2008, 09:44 PM   #1
12-volt fresh water pump
Do fresh water pumps have to have a pressure tank setup? Is a 2.8 gpm pump large enough?
Abbott is offline   Reply With Quote
Old 06-18-2008, 11:12 AM   #2
Re: 12-volt fresh water pump
So a pressure tank is needed, what can I use to build one? Do I install it right after the pump? Is there any type of special fitting or valve that needs to be in the line because of the pressure tank?
I plan to have a kitchen sink, toilet and tank-less hot water heater.
Old 06-18-2008, 11:37 AM   #3
sportyrick's Avatar
Chassis: F33695
I bought a surge tank from an RV supply, it's about the size of a large potato and does a good job. If you buy one for a shallow well pump it might be too large, I'm not sure. I would reccommend using one or the pump will cycle all the time and burn up. Also the RV style surge tank has pipe threads which I screwed right to my pump and then a fitting to run PEX tubing on the other side which I also reccommend using. I also got a sediment bowl/screen type filter to keep unwanted uglies out of my water supply and pump. Don't forget to drain all this when winter comes or it will all freeze. sportyrick
Old 06-18-2008, 11:41 AM   #4
Hi Rick, thanks for the post (and everyone else as well).
I am checking Google for them now, I found this tank here for about $40.00 bucks Click, that's not bad.
Old 06-19-2008, 08:49 AM   #5
sportyrick's Avatar
Chassis: F33695
that picture is exactly what I have. It does hold a little water and keeps the pump from running all the time. You can get about a cup of water out of the system before the pump starts up or if you have a dripping faucet it will keep the pump from running constantly on and off. It doesn't take much water loss to drop the pressure and start the pump if a bladder isn't present. It's a smaller version of the system that I had with my deep well pump when I lived in the country. sportyrick
Fresh water pump question BUSBOZO Conversion General Discussions 1 03-22-2010 12:37 PM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 06:26 PM
Need good used 12 volt water pump frank-id Classifieds | Buy, Sell, Swap 0 09-22-2006 10:46 PM
fresh water tank bocephus Everything Else | General Skoolie Discussions 5 12-21-2005 08:01 PM
Fresh Water Systems Steve Conversion Tutorials and How-to's 0 06-16-2004 12:38 PM
