Old 01-24-2008, 04:49 PM   #1
alternative to PEX crimpers?
I was looking at PEX tubing at Lowes, it sure looks like it can simplify the plumbing in a bus. But.....is there an alternative to the $83 crimping pliers? That would steer me away from it.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 01-24-2008, 06:08 PM   #2
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Re: alternative to PEX crimpers?
My local (b)Lowe's has threaded fittings with seals that I am using on my pex. I haven't had any leaks yet, knock wood (*raps knuckles on head*).
I realize it's kind of hard to see them in this shot, but if you look to the left of the toilet, you can see a "tee" fitting that uses them on the "through" legs:
http://thewhiteelephantstale.com/ima...lav/lav002.jpg
Griff is offline   Reply With Quote
Old 01-24-2008, 06:17 PM   #3
I can't quite see them. I did see some push-on fittings at Lowes that would be great if they weren't $5+ each! It looks like good old PVC might be the ticket on this one.
Brad Davis
"Big Blue"
Old 01-24-2008, 08:06 PM   #4
BusNut's Avatar
I haven't tried it myself, but a senior member on the MAK board found that the appropriately sized (1/2" or 3/4") electrical crimpers worked well and that he had no leaks on any of the connections made with them. He found them at a pawn shop for $15 (I've seen them at flee markets for about that). He said the crimp heads were identical to pex crimpers even when compared using a micrometer. And the electrical crimpers had longer handles making them easier on the hands.
BusNut is offline   Reply With Quote
Old 01-25-2008, 03:25 PM   #5
I was told those work great also, but I just have a hard time paying that much for one fitting, that could add up fast.
Brad Davis
"Big Blue"
Old 01-27-2008, 08:29 PM   #6
hey ya'll.
i've got the yankee tool pex crimper and it rocks. does 3/8, 1/2, and 3/4 and only costs about $40.
http://pexcrimper.com.hosting.domaindirect.com/
i wouldn't use anything but pex crimp rings for pex tubing, but maybe that's just me. those push fittings make me nervous. in my county no type of push connector is approved for in wall applications.
also, check your local plumbing supply store rather than lowes...you'll find the price of rings and fittings to be about 1/3 the cost of lowes.
blueindian is offline   Reply With Quote
Old 01-27-2008, 09:26 PM   #7
bus-bro's Avatar
Engine: 3208 na boat anchor
Cool tool, blueindian.
Old 01-27-2008, 10:10 PM   #8
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
ive never seen that before but i sure like it thanks blue indian i lkie that it still needs your standard vise grips to work
Old 01-27-2008, 10:28 PM   #9
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
I've used the sharkbite style fittings a couple times on PEX in mobile homes. It works slick. I like the screw together kind from the RV shop better, but they're about $11 each.
Firearm is offline   Reply With Quote
Old 01-28-2008, 10:24 AM   #10
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Hi-
We used the Flair-It fittings on the 1/2" PEX tubing that comprises our plumbing system. Probably 16 or so in total, used in both hot & cold, also in pressurized & unpressurized portions of the system. Zero problems in 1.5 years of full-time use. I like not having another tool taking up space.
HTH,
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 02-11-2008, 09:56 PM   #11
some plumbing stores will rent out crimpers for cheap. all you'll need to do is put down a damage/theft deposit and it will be returned to you when you bring it back
garrett is offline   Reply With Quote
Old 02-11-2008, 10:59 PM   #12
Elliot Naess's Avatar
Engine: 5,9 Cummins
A local plumbing supply store just told me that PEX varies in diameter by brand, so this may be a factor for the push-together fittings. What he showed me were short lengths of thick stiff PEX, maybe five feet long, versus long coiled-up PEX that is more flexible but thinner, and the shark bites may not get a good enough grip. These were both labled 1/2 ". Sound right?
Old 02-12-2008, 07:25 PM   #13
I used the shark bite fittings from HD...Very happy with the results..Little pricey,,But for speed and easy no leak conections its the way to go...Oh dont forget the fitting release tool screw up and you cant pull it apart..its about 79cents and worth every pennie....
colliervilledave is offline   Reply With Quote
Old 02-12-2008, 10:39 PM   #14
Well I solved the same predicament by buying the tool then returning it. I couldn't find one to rent around here and yeah they're just too expensive.
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Alternative Energy paul iossi Conversion General Discussions 9 Today 10:42 AM
Mr Heater alternative. crazycal Everything Else | General Skoolie Discussions 4 12-02-2013 10:15 PM
Alternative ceiling material chaos Conversion General Discussions 6 03-09-2010 10:38 PM
Alternative Fuel?? drchefscott Alternative Fuels | Electric, Propane, Wood & Biofuels 11 02-21-2009 05:22 PM
Alternative plumbing pangaia Skoolie Conversion Projects 7 01-24-2005 02:04 PM
